Sponsored by: Innova
Fuse for power wire
Old Aug 27, 2007 | 01:50 AM
Vette-kid's Avatar
Vette-kid
Default Fuse for power wire
Im running two amps, a JL 300/2 and a Kenwood Excelon KAC-X10D (rated at 600WRMS). I have a 4 ga. running from the battery into a fused distro block and seperate 8ga wires to the amps. My question is, Do I need to have a 3rd fuse on the 4ga wire near the battery? And what size is appropriate for the distro block? I have 55amp fuses in it now.
Old Aug 27, 2007 | 02:01 AM
Kale's Avatar
Kale
You MUST have a fuse within 12" of the battery. For 4 gauge, 115 amp fuse would be fine.
This fuse protects the wire. Otherwise, you short that wire out, it's car fire time.
Old Aug 27, 2007 | 02:15 AM
Vette-kid's Avatar
Vette-kid
Wow, glad I asked! So are the fuses at the distro block still necassary, will they be ok to leave in if not (so I dont have to pull that out...more work )
Old Aug 27, 2007 | 02:27 AM
Kale's Avatar
Kale
Yes.
You must fuse every time you have a power wire size reduction.
Otherwise the small wire might /become/ the fuse.
Old Aug 27, 2007 | 02:34 AM
Vette-kid's Avatar
Vette-kid
Got it! Sounds like you saved me from some major headaches later. Is there a formula or even simpler, a website, for finding the right fuse size? It should be based on the wire size right? Thats what your protecting, not the amps...right?
Old Aug 27, 2007 | 08:48 AM
BAND1T's Avatar
BAND1T
The fuse is used to protect both - either to protect the power source which includes the wire that connects the power supply to the electrical device, or to protect the electronic equipment.
Suggested Fuse Sizes:
Wire Gauge Recommended
Maximum Fuse Size
00 awg - 400 amps
0 awg - 325 amps
1 awg - 250 amps
2 awg - 200 amps
4 awg - 125 amps
6 awg - 80 amps
8 awg - 50 amps
10 awg - 30 amps
12 awg - 20 amps
14 awg - 15 amps
16 awg - 7.5 amps
These are the recommended maximum fuse ratings for the corresponding wire size. Using a smaller fuse than what's recommended here will be perfectly safe.
(courtesy from BCAE)
TJ
Old Aug 27, 2007 | 10:23 AM
Kale's Avatar
Kale
BCAE1 is a great place to learn about this stuff.
You fuse for wire, not for amps.
Old Aug 27, 2007 | 11:33 AM
Vette-kid's Avatar
Vette-kid
Awsomw site, thanks for the info guys!
To Fuse for power wire
