Sponsored by: Innova
Blown Speaker???
Old Aug 30, 2007 | 11:07 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Blown Speaker???
I have a newly installed set of Infinity 6010cs. They are in the front doors. I noticed that the right side on some music, the sound is all distorted.
I have the tweeters set on the lower setting (-1db) on the crossover. I also had the Amp set to high pass on 80mhz. Which gave the system to much bass. Now I have it closer to 120mhz it sounds a little better but not awesome.
Is the speaker gone? It does not do it on all songs, just mostly hard rock, which I like. So that is what I have on my iPod.
Advise?
Old Aug 30, 2007 | 11:13 PM
VinceC5's Avatar
VinceC5
Advise?
Is this your first time using the ipod in the car? If so, you may want to turn of the EQ on the ipod. I had mine on and had similar sound until I turned off the EQ setting. Then again it could be anything from a bad channel on the amp or just exactly as you say - a blown speaker.
Old Aug 31, 2007 | 08:24 AM
screw991le's Avatar
screw991le
Thanks, but the EQ is off. Can I use any tweeter to replace the one I have or does it need to be the same type?
Old Aug 31, 2007 | 08:53 AM
VinceC5's Avatar
VinceC5
try and stick to the same type. But if you are just testing for the problem, then you can use any tweeter.
Old Aug 31, 2007 | 09:43 AM
screw991le's Avatar
screw991le
Recommend a cheap replacement?
Old Aug 31, 2007 | 11:11 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Im shocked u blew the tweet, when I used to run the refernece components I beat the hell out of them and way over powered and never an issue with the tweets
Old Aug 31, 2007 | 01:12 PM
screw991le's Avatar
screw991le
It is not crackling or such, it just sounds distorted. I am going to fool around when the amp setting a little more and see.
Old Aug 31, 2007 | 03:45 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
try downloading and playing high frequency test tones:
http://www.marchandelec.com/sweeps.htm
turn your fader and balance towards the speaker in question. The tweeter should be able to play cleanly through all the frequencies.
Tweeter distortion can somtimes occur with a poor connection or a loose mount. This happend in my silverado, the tweeter in the door broke off the plastic mount and fell into the door resulting in horrible sound.
To Blown Speaker???
