Sponsored by: Innova
I need HELP from an Electronics Wizard
Old Aug 31, 2007 | 02:12 PM
Jim Martley2's Avatar
Jim Martley2
Default I need HELP from an Electronics Wizard
I have a 12 Volt DC Linear Actuator that I want to extend when I apply power and automaticaly retract when I shut the power off.
How can I accomplish this? CHEAPLY!!!!!!!!!
Jim
Old Aug 31, 2007 | 02:30 PM
Vette-kid's Avatar
Vette-kid
Well Im no electronics wiz, but could yuo hook it up like an amp. depending on how the unit is wired it could be tricky to get it to come down automatically though. What is this for?
Old Aug 31, 2007 | 02:37 PM
Jim Martley2
As crazy as this sounds, this is for a retractable back up light on my 82. I have always loved the 4 red tail light look of the earlier and later Corvettes and I replaced my 2 inboard back up light lenses with red tail light lenses and wired in new sockets. I temporarly installed a couple of SMALL driving lights under the car but am NOT happy with the look of it. I found this actuator and it will work well for raising & lowering a light but I need to find a wat for it to lower when I put the car in reverse and raise when I take it out of reverse. I will use the existing back up light wiring as a "trigger source" for the circuitry.
Jim
Old Aug 31, 2007 | 02:53 PM
Vette-kid's Avatar
Vette-kid
Thats an interesting solution but sounds overly comlex. Could you not just use a dual lense in which a small portion toward the bottom is dedicated for reverse lamps?
For the actuator, thre should be a signal wire from your shifter that energizes when you shift into reverse. This is how your back up lights normal come on and off. When you go into reverse it completes the circuit and the lights come on. I would think you could tap into that, but you would have to find a way to make it a temporary condition. So when you put it into reverse it makes a contact for a few seconds to allow the actuator to raise and then disconnects, leaving the actuator in that position. Then when you shift out of reverse again it would need to make the same temporary connection again to allow the actuator to lower. I have no Idea how you would accomplish this though. Maybe post pics if you have them so we can see what you are trying to acomplish better (sounds kinda cool).
Old Aug 31, 2007 | 03:01 PM
Jim Martley2
As a boss of mine used to say "if it was easy, EVERYBODY would want to do it".
I have to believe there is some type of circuitry out there to do what I want. I just don't know where to start looking and am hoping that someone on this forum might know.
I will have to check my wiring diagram for my 82. I just remembered that my power antenna works EXACTLY the way I want this actuator to work!!!!
Jim
Old Aug 31, 2007 | 03:04 PM
Vette-kid's Avatar
Vette-kid
hmmm...a modified power antenna relay could do the trick. Im sure there are some experts on this site who could figure it out easily, but most of them seem to be on here later at night.
Old Aug 31, 2007 | 03:08 PM
Jim Martley2
I'll have to keep an eye on this site during the evening tonight. I will be out of town from Saturday morning thru Monday afternoon so if I don't respond PLEASE keep the ideas coming!!!
Old Aug 31, 2007 | 03:32 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
If i'm not mistaking, the L.A. requires power to retract. Depending on the switch you're using, you could wire what would normally be the ground on the switch to the retract on the Actuator. This only works with toggle style switches...
on a sidenote, i'm curious what devious contraption you're planning
Old Aug 31, 2007 | 03:34 PM
Fasthotrod's Avatar
Fasthotrod
Jim,
Let's back up a second. You say you have a linear actuator that you want to use to raise and lower the lights, correct? These lights will be used for your 'reverse' lights while backing up, and retracted when driving normally, right?
We need more information regarding the actuator. Some have built in limit switches, as others do not. It's not a big deal, I can can design a circuit either way... I just need to know what I'm working with.
So just to make sure I understand: You want to 'trigger' the actuator to lower the lights into position when your car is placed into reverse. Any other shifter position and you want the actuator to tuck the lights back up, right?
If this is what you want, it should be an easy circuit. Let me know.
Mark
Old Aug 31, 2007 | 03:36 PM
Vette-kid's Avatar
Vette-kid
try this also http://www.the12volt.com/relays/page5.asp
Old Aug 31, 2007 | 03:57 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Need more info about the actuator but let me make a couple assumptions..... The actuator is dual motion, right? out and back? Then it must be either driven out and "spring" back or driven both ways. If it is driven both ways then I would expect that there are connections for positive, ground, and a trigger. If that's the case then wire the positive direct to constant 12vdc and the ground to, well, ground. Connect the input trigger to your back up lights. When they come on they trigger the actuator to extend and when they go off the removal of the trigger retracts the actuator.
Old Aug 31, 2007 | 05:30 PM
Jim Martley2
Originally Posted by Fasthotrod
Jim,
Mark
Mark,
Yes, I already have the actuator. It requires 12VDC to power it in either direction. I have to somehow reverse the polarity to get it to do what I want.
The actuator has built in limit switches.
Your description of what I want to do is exactly what I want to have happen.
Thank you,
Jim
Old Aug 31, 2007 | 05:35 PM
Jim Martley2
jbondfl,
The actuator is dual motion ONLY if I reverse the polatity. It requires power to go in either direction.
There is only a 12V+ connection and a 12V- connection on the actuator. There is no 3rd trigger wire. I WISH it were that easy.
Jim
Old Aug 31, 2007 | 06:59 PM
robvuk's Avatar
robvuk
Originally Posted by Jim Martley2
jbondfl,
Jim
If your actuator has built in limit switches this means when you apply voltage in either direction, it will shut off automatically. Correct? If this is correct, I have your simple solution. All you need is a double pole, double throw 12v relay with enough current capacity to power the actuator, whatever that is. Probably less than 2A. I guess around $5-$10. Let me know if you want, I'll draw and scan a schematic for you.
Old Aug 31, 2007 | 07:50 PM
Vette-kid's Avatar
Vette-kid
like this?
Old Aug 31, 2007 | 08:08 PM
Jim Martley2
If you could draw me a schematic showing where to hook my wires to , it would be appreciated. I believe I need :
1- 12V+battery power
1- 12V+ switched power (original back up light wire)
2- wires on Actuator for + & -
and any ground wires.
I just found a source for the DP/DT relay. The picture shows 8 terminals !! I figured the terminals that power the coil would hook up to my existing back up light 12+ and ground wires, right? How would the rest of them hook up?
Thanks,
Jim
Old Aug 31, 2007 | 10:07 PM
adown's Avatar
adown
Your relay will have normally closed contacts that will make when it has no power. Those are the contacts you want to use for the non backing mode. When you power the relay the contacts that are made are the ones you want to use for backing up. You can ohm out the contacts to see if it doesn't show which are normally closed. With 8 contacts you will have 2 coil wires, a power and ground input and a set for normally closed and a set for closed when energized. The relay should have a schematic on it.
To I need HELP from an Electronics Wizard
Old Aug 31, 2007 | 11:03 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
A relay will give you the current you need in the "on" and "off" modes. However if you need to switch current direction that's going to be fun. Sounds like you'll need two ground wires (one for each direction) You'll need polarized Diodes to keep the current from backflowing. I'll do some sketching tomorrow and see what wiring setup might work.
Old Sep 1, 2007 | 04:07 AM
robvuk's Avatar
robvuk
Like this. Simple logic. No transistors, no resistors, no diodes, no capacitors, no magic. Just a relay. Have fun!
no= normally open
nc= normally closed
Old Sep 1, 2007 | 07:25 AM
adown's Avatar
adown
radio f, robvuk is right. You wont need any diodes, the nc contacts will break before the no's are made.
