Sponsored by: Innova
Speaker question
Old Sep 7, 2007 | 09:42 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Speaker question
I have a set of Infinity 6010cs component speakers. I installed them in April, now the passenger side sounds distorted only on the songs vocals. The music is fine, but the persons voices sounds like it is playing under water.
So, I swapped channels to see if it was the amp, no. The drivers system sounds fine.
I have a replacement set coming in Monday.
My question is, Could it be the crossover in the system? Can I by pass the speaker's crossover and use 2 more channels on the amp to drive the tweeters? Then use the other 2 channels to drive the woofers? Using the amps crossovers to tune the sound?
Right now I have the amp set on high pass at 80. With the speaker's crossovers attached.
Thanks for the input.
Old Sep 7, 2007 | 10:02 AM
Spkrboy's Avatar
Spkrboy
It's highly unlikely it's the XO unless the capacitors are fried from being either cheap and/or over-driven. Still unlikely, but possible.
You can do what you're thinking with the amp, but to do it well, it's more complicated than it sounds.
Old Sep 7, 2007 | 11:14 AM
Kale's Avatar
Kale
Can your amp cross over in the 3-5khz region?
Old Sep 7, 2007 | 11:16 AM
screw991le's Avatar
screw991le
Here is what the manual says
variable filters (low-pass from 50-250 Hz, high-pass from 80-1200 Hz, at 12 dB per octave)
Old Sep 7, 2007 | 11:17 AM
Fasthotrod's Avatar
Fasthotrod
I had a set of Infinity speakers in my C5 and my Suburban. Both had problems when the heat got too high inside the vehicle. The cones warped and pulled away from the surround.
They quickly found their way into the trash bin.
Hope you have better luck than I did.
Mark
To Speaker question
