Sponsored by: Innova
Help!!! Ignition Bypass!!!
Old Sep 9, 2007 | 11:45 PM
TryNkeepUp's Avatar
TryNkeepUp
St. Jude Donor '08-'09-'10-'11-'12
Default Help!!! Ignition Bypass!!!
Ok, here's the dilemma........I've got a 99 vette with the dreaded key chip. My VATS shuts the car down on a regular basis and it's getting out of control
I've already done the following:
Shut off the VATS in the computer - NO GOOD - this only shuts off the alarm in the PCM but does not bypass the BCM in looking for the resistance from the key chip/cylinder.
Replaced the key itself.........NO GO
I've searched every Vette magazine and haven't been able to find a bypass that will guarantee it will work on a C5.......
The cylinder has yet to be replaced and Undertaker found this for me
http://members.tripod.com/~alarmtek/VATS.html
Suggestions???? I'm desperate........I can't have this shutting down on me as I'm ready to roll out into the staging area for an HPDE session.
TIA everyone!!
Old Sep 10, 2007 | 10:20 AM
DPG's Avatar
DPG
St. Jude Donor '06
I would think that replacing the cylinder would do the trick. Never heard of that bypass for that link you posted. I have heard of some people just adding a resistor under the dash somewhere, but haven't seen any write up on it.
Old Sep 10, 2007 | 08:51 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
Vehicles with the GM VATS system have a resistor embedded in the ignition key. If
the VATS decoder module does not measure the proper resistance when the vehicle
is started, the starter and or fuel pump may be disabled for up to 10 minutes. There
are 15 possible values used for these cars (listed below). The “VATS Pack” is part
number 652t and contains all 15 values.
The VATS wires will be two very light gauge wires coming off the key cylinder. The
colors of the wires may vary but they are contained in a tubing that is often orange,
black, or gray (do not confuse this with the yellow tubing which is for the airbag
wires!!!!). Determine the value of the resistor in the key with a multimeter, then
follow the diagram above to bypass VATS during remote start operation.
NOTE: When connecting to the VATS wires it is not important which wire is cut
but make sure that the key side of the cut wire goes to terminal 87A of the relay and
the car side goes to terminal 30.
Jimmy 2 Times
the picture didn't post, give me your email, and I will send it to you
Old Sep 10, 2007 | 09:03 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
it is bypassable there is a module to do it used for adding remote starts, if you wire it properly it will always bypass, therefore always work
Old Sep 10, 2007 | 09:21 PM
TryNkeepUp's Avatar
TryNkeepUp
PM sent - Thank you!!
I've seen a few bypasses, but they all state that they will not work without the remote start being engaged
I've researched this almost to death!
If replacing the cylinder doesn't work, I'll try the relay next and if that doesn't work.......I'm going to gouge my own eyes out
Thanks guys!!
Old Sep 10, 2007 | 11:21 PM
Jimmy 2 Times
you don't need a bypass, you need a 2cent resistor, some solder, and some black tape....and dont forget your dmm
To Help!!! Ignition Bypass!!!
