I've heard het many wonders of active crossovers and it's to the point where i'd like to try it out. My setup is currently running the following:
ERA G320 processor (Front/Rear/Sub RCA outputs)
(2) Alpine MRP F250 Amps running bridged (I could change the wiring to run x4 so each driver gets it's own channel)
(2) Alpine SPX 177r comp sets.
2 questions:
a) If i were to go active, would I still need to keep the passive crossovers?
b) Looking for a quality two 2 ch 2-way crossovers. (to keep things neat, I'd like to have the fronts and rears to have seperate xovers that i would mount under the amps. What do you guys reccomend?
My Processor has a subwoofer crossover (though i have yet to figure it out) and my CDA 7998 head unit has most of it's processing being taken over by the ERA G320 with an Ai net connection. I also have a seperate bass processor for the sub (Epicenter 150)
see if you can sell the era g320 and upgrade to the h701 (can be found pretty reasonably used on ebay) this will handle all of your processing needs/wants/desires.
or while you're saving your money you can wait to hear my impressions of the behringer dcx2496 w/12v mod.
brand new you can walk away from that @ about $400 and it's supposed to be easier to use then the alpine and it has a more intensive eq system
oh...another one to check out is the ppi unit that fej is using
a) You still need a few passive components to do this correctly (most people don't, IMO).
b) Whatever you use, it should have integrated level control and not just frequency. If you're really serious, get phase control and more than 12dB/octave.
7998 I believe is capable of 6/12/18/24 and also up to 10db of attenuation on the channels... if he uses it in 3 way mode.
Spkr is referring to proper impedance control via the passive crossovers, which active units do not account for (at least that I know of). Home theater yes IMO, car audio not really necessary if you are active. The environment has enough issues without worrying about the impedance curve (again IMO).
If you are going active, I recommend using the 7998 in 3 way mode, dropping the passive boxes altogether (which likely do not account for impedance anyway), and using the HU to handle all of your processing needs, at least at first. If you still feel you need some more tuning capability than the H701 scott recommended is a great option, just make small changes as Spkr recommends. Lots of ways to improve, or degrade your system's sounds in that little box.
I personally am quite happy with my Eclipse 8053 as an all-in-one solution for processing/eq/ta. Worth looking into with your 7998 and does not cost you any more money.
So I just ordered the Arc Audio MX-3, Dynaudio 172 woofers and Seas tweets. I am going to go active with this. What passive components do I need to do it right?
I have the DNX7100 which I do not believe has a 3-way mode so I will have to do this with the MX-3.
Shan
dyn 172s are pretty much flat on the impedence in their midrange area, seas (assuming you got the textiles)
impedence is pretty flat on the seas neos in the range you are using too. MHO, I wouldn't worry about it.
i'm not agreeing nor disagreeing with it, i was just assuming he meant more then a zobel. I have no experience with any of the diy passive circuits, i dont know how much a benefit i'd actually hear from them. but it's fun to learn
Scott: From what I've read regarding the owners's manual the PXA H701 only has a 2 way active crossover for the fronts.
Originally Posted by Kale
I think the 7998 will handle active, IF you are willing to give up rear speakers.
...nooooo
Since i'm using the ERA G320, my 7998 won't give my Xover adjustments. I do however get seperate 7 band equalization for front and rear speakers from the ERA g320.
Originally Posted by Shangreer
All I know is that I need to quit hanging out with you guys here. You all are costing me a fortune. My Hot Tub money all went into the Vette Stereo.
Look on the bright side.....you can't drown in a stereo
