Sponsored by: Innova
C5 coupe antenna wire
Old Sep 24, 2007 | 08:28 PM
RedRiderZR1's Avatar
RedRiderZR1
Default C5 coupe antenna wire
I'm wiring in my kenwood 7100 and am trying to figure out which one of the dark Green wires do you connect the +5 volts too to connect the rear antenna. The Big connector or the small 3 wire connector.
Thanks.
Greg
Old Sep 25, 2007 | 11:01 PM
adown's Avatar
adown
I believe the green wire gets 12v and the pink wire gets 5v. Check the audio fac's, there's a lot on it.
Old Sep 26, 2007 | 11:04 AM
robvuk's Avatar
robvuk
You have a C5 coupe with a rear antenna????
Old Sep 26, 2007 | 03:39 PM
SilverC54me's Avatar
SilverC54me
Greg
All that is needed is the 12V Green wire. I had done both the 12V and 5v signals to the antenna amp but found that with the 5V off (not applied) I got better reception. In order to get AM the 5V needs to be off also.
Give me a call tonight if you still need help with this.
Gary
To C5 coupe antenna wire
