Sponsored by: Innova
C5 Z06 Amplifier Ground
Old Sep 27, 2007 | 06:43 PM
Khlept0's Avatar
Khlept0
Default C5 Z06 Amplifier Ground
I've done a lot of searching and see some people opt to ground your amp out on a seat bolt. Does anyone have pictures of how you've done this?
I'd like to actually not have the ground that far away, though if possible.
Where did you ground your amp?
Stories!
Old Sep 27, 2007 | 07:00 PM
Kale's Avatar
Kale
factory ground point under plastic panel between seatbelt reel and top. do a search.
Old Sep 27, 2007 | 07:09 PM
Khlept0's Avatar
Khlept0
Actually, now that I search for seat belt I found your post with pics.
Thanks =]
Old Sep 27, 2007 | 08:08 PM
Kale's Avatar
Kale
Thanks =]
its a great spot. be sure to sand first.
Old Sep 27, 2007 | 10:00 PM
Spkrboy's Avatar
Spkrboy
And spray over it with rubberized undercoating after the bolt is in place to keep it from corroding.
Old Sep 27, 2007 | 10:35 PM
Kale's Avatar
Kale
this one is inside the car.
Old Sep 27, 2007 | 10:44 PM
Spkrboy's Avatar
Spkrboy
Here in PA, large temperature changes cause humidity changes inside the car whether it's stored or not. It'll corrode over a couple years.
Old Sep 28, 2007 | 07:24 PM
Khlept0's Avatar
Khlept0
Well The job is complete and it sounds great.
For anyone who is searching, there is a spot right below where your seatbelt coils into on the passenger side. Unbolt the little black thing and dremmel the black coating off then you should be golden.
To C5 Z06 Amplifier Ground
