Sponsored by: Innova
Remote Turn On
Old Oct 3, 2007 | 10:35 AM
BadYellowCorvette's Avatar
BadYellowCorvette
Default Remote Turn On
Ok I've one last final question and I'll be done with my system. I tried a search and looked through the FAQ's but couldn't find any answers. I've kept my factory bose cd player and stock speakers, but just added a sub and amp. I ran my remote turn on wire to the passenger side fuse panel and tapped in the rdo cd fuse and it works, however when the key is off the amp is still powered up. My question is, which fuse can I tap in to give me power to my amp only when the key is on?
Thanks,
Derek
Old Oct 3, 2007 | 10:40 AM
Fasthotrod's Avatar
Fasthotrod
You couldn't find this in the FAQ?
How do I get the acc power for my h/u?
if you look in the passenger footwell, pull out the cover and look in the top left corner. There will be a small plug with three wires (orange, yellow, & black) that are just taped up. Check out this schematic to see which fuses they use, but the yellow wire is the +12V switched, and that I am sure of.
It was in the first post. How hard did you really look?
The yellow wire is the accessory lead. Use this to turn your amp on and off.
Mark
Old Oct 3, 2007 | 11:45 AM
BadYellowCorvette
Mark
Thanks for your help Mark, I must have not seen it but I did look.
To Remote Turn On
