Sponsored by: Innova
Poly Fill?
Old Oct 10, 2007 | 06:13 PM
Buddy A's Avatar
Buddy A
Default Poly Fill?
Where to buy Poly Fill? Is this purchased in a fabric store?
TIA
Old Oct 10, 2007 | 06:36 PM
Kale's Avatar
Kale
yes.
Old Oct 10, 2007 | 11:47 PM
Spkrboy's Avatar
Spkrboy
There are outlets that sell "acoustical polyfill" as though that made any difference. Don't buy into any hype. It's all the same when the material is the same.
Old Oct 11, 2007 | 12:47 AM
rcmigpilot's Avatar
rcmigpilot
If you can't find it at a fabric store Crutchfield has it.
http://www.crutchfield.com/S-SDcQYBp...g=741&I=027808
Old Oct 11, 2007 | 01:19 AM
Kale's Avatar
Kale
btw, pretty much any walmart/target/kmart has it too. Really cheap. I used to buy a ton of this stuff for my fish tank,. Makes great water polisher.
Old Oct 11, 2007 | 09:11 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Parts Express also sells it.....
Old Oct 11, 2007 | 05:20 PM
Buddy A's Avatar
Buddy A
Thanks guys. Do I pack it loosly or fairly dense?
Old Oct 11, 2007 | 05:38 PM
Spkrboy's Avatar
Spkrboy
That depends on the box you're stuffing and the reason you're using the polyfill.
Old Oct 11, 2007 | 06:07 PM
Buddy A's Avatar
Buddy A
Because I have the ED 12" and saw the recent test done on the 10". Saw where the box size on the 10" was way off. So I thought I'd try to put some poly in the box to see if performance increased. Right now the box is 1.18 cubic feet. When I push it hard the sub will "rumble or shake". Don't know how exactly to describe it. It's like the speaker can't extend outwards enough. When it begins to extend too far, it'll sound bad.
Old Oct 11, 2007 | 06:21 PM
Spkrboy's Avatar
Spkrboy
I'm not sure what you're describing, but in your case, 1 lb per cubic foot is the rule of thumb. Adjust for taste thereafter.
Old Oct 11, 2007 | 06:46 PM
Buddy A's Avatar
Buddy A
When I push it, it begins to sound distorted. Not clear when I increase the volume. Just figures that the polly fill is cheap enough to experiment with. Thanks. Guess I'll have to start loose and go from there. See what sounds better.
Old Oct 11, 2007 | 08:12 PM
Puggah's Avatar
Puggah
Well, your issue could stem from a few things. What comes to mind first:
*Not enough power.
*Pushing sub past its limits. (too much power or box too big)
polyfill is not the answer.
Old Oct 11, 2007 | 10:08 PM
Spkrboy's Avatar
Spkrboy
This thread will explain the purpose of damping materials like polyfill.
http://forums.corvetteforum.com/show....php?t=1697129
Old Oct 11, 2007 | 10:32 PM
Buddy A's Avatar
Buddy A
I've got 600 watts at 4 ohms going to it. So then should I try to reduce the box size and see what happens?
Old Oct 11, 2007 | 11:34 PM
Spkrboy's Avatar
Spkrboy
There's no way to know how that will affect the driver's performance without some test equipment, so no. You have too many unknowns for us to really do anything with. Kittah might be right about the sub being over-driven (too little power, though, is not the problem). It also might already be damaged. It might be that it's the wrong box. It might be functioning normally, and you're simply unhappy with its performance. Like I said, too many unknowns.
Old Oct 12, 2007 | 09:32 AM
Buddy A's Avatar
Buddy A
Default Dif. sub?
Ok how about a new direction. With a sealed box at 1.18 cubic feet and 600 watts at 4 ohms which sub would you rec.??
Old Oct 12, 2007 | 10:29 AM
Kale's Avatar
Kale
What's your mounting depth and price range? I was very happy with an IDMAX in that amount of airspace on 400w.
Old Oct 12, 2007 | 12:36 PM
Buddy A's Avatar
Buddy A
8" total. Price range? Reasonable, $200-$250. I think I paid $150ish for ED.
To Poly Fill?
