Sponsored by: Innova
HOW MANY WATTS
Old Nov 15, 2001 | 10:46 AM
JIM50's Avatar
JIM50
Default HOW MANY WATTS
CAN SOMEONE PLEASE TELL ME HOW MANY WATTS ARE IN A 2001 CONVERTIBLE RADIO /W/C/D.MANUALS DON'T HAVE ANY INFO AND THE DEALER IS NO HELP.THANKS JIM50
Old Nov 15, 2001 | 04:17 PM
Jim Kramer's Avatar
Jim Kramer
Default Re: HOW MANY WATTS (JIM50)
I think the reason for that is that it's a pretty low number. I know you probably would rather have more than an educated guess, but I believe the power to be in the area of 20-25 Watts to the front Bose (they are amplified separately), and about 10 Watts to the back. I will search for some posts by 99HT - I thought he had the numbers.
-Jim
Old Nov 15, 2001 | 04:20 PM
Jim Kramer's Avatar
Jim Kramer
Here is the thread:
http://forums.corvetteforum.com/zerothread?id=131778
it states:
The head unit internal power amp is about 15-18 watt rms/ch and drives the 4 front and rear Bose midrange/highs speakers called Twiddlers. The rear Twiddlers are 5.25" and the fronts are 3.5". The Bose system has no true tweeters.
Hope that helps!
-Jim
P.S. Thanks 99HT!!! :cheers:
Old Nov 15, 2001 | 04:53 PM
EvilDeed's Avatar
EvilDeed
Cruise-In II Veteran
I know that I have 1600 watts in mine. :yesnod: Hehehe.
Jim
Old Nov 15, 2001 | 04:55 PM
Fast one's Avatar
Fast one
Default Re: HOW MANY WATTS (VetteMan2k1)
The shop book rates the total power as 252 watts, each door power amp for the large speaker is rated at 100 watts. Both 100 watt amps are fed with a common 20 amp fuse so 12 volts x 20 amps max = 240 watts of feed power. 240 watts x 80% efficiency = 192 watts peak or close to the rating on the amps. Of course the total power output is only one aspect of the total system performance.
Old Nov 15, 2001 | 05:40 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: HOW MANY WATTS (Fast one)
Ask 99HT in the audio section, and you will get an exact answer.
Speed-Racer
Old Nov 15, 2001 | 10:09 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: HOW MUCH HP IN MY RADIO?
There are 746 watts = 1 hp
Now you figure it out! :) What was the question?
[Modified by wallstAL, 6:11 PM 11/15/2001]
Old Nov 16, 2001 | 11:40 AM
99HT's Avatar
99HT
The real power depends on what distortion rating and frequency you want to use. An amp can put out more power when run at 10% distortion than at say .1%.
This is a rough estimate. The 4 channel internal AB power amp in the HU is about 14 -18 wrms/ch into a 4 ohm speaker. This amp drives the four Bose Twiddlers. The door class D sub amps are about 35 to 45 wrms each into a 2 ohm speaker. Each sub amp drives a 2 ohm Bose reverse cone sub woofer. Since the Bose system has no DC to DC converter like an aftermarket power amp would, the amps are running directly off the alternator's 14 volts.
Calculations:
Class AB balanced amp powered by 14 volts and driving a 4 ohm speaker
Assume voltage swing out of the + and - output of the amp to be roughly 11 volts peak to peak. Convert p-p to rms.
(11/2).707 = 3.9 vrms
A balanced amp design provides 2x the voltage swing to a speaker.
2(3.9) = 7.8 vrms
Power into a 4 ohm speaker
(Vrms*Vrms)/R
(7.8*7.8)/4 = 15 wrms
Class D balanced amp powered by 14 volts and driving a 2 ohm speaker
Assume voltage swing out of the + and - output of the amp to be roughly 13 volts peak to peak. Convert p-p to rms.
(13/2).707 = 4.6 vrms
2(4.6) = 9.2 vrms
Power into a 2 ohm speaker
(Vrms*Vrms)/R
(9.2*9.2)/2 = 42 wrms
Old Nov 16, 2001 | 01:06 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: HOW MANY WATTS (99HT)
I would tell you, but you're YELLING :nono:
Old Nov 16, 2001 | 06:22 PM
darkmercury's Avatar
darkmercury
OK... I felt like I was in High School Electronics class again!!!
Oh... good to know we don't have true tweeters and that's why I can't get a good crisp high frequency to my ears. :yesnod: :crazy:
Old Nov 16, 2001 | 07:34 PM
ShanMan14's Avatar
ShanMan14
Cruise-In V Veteran
Default Re: HOW MANY WATTS (darkmercury)
Moving to Audio
To HOW MANY WATTS
