Sponsored by: Innova
C5 Bezel modders - show us your backside
Old Oct 17, 2007 | 04:26 PM
hangpilot's Avatar
hangpilot
Default C5 Bezel modders - show us your backside
What to use? What to use?
I am getting ready to do the double din bezel mod. I am wondering what materials most use to back the bezel, since it will be narrower than the stock width. The audio section shows a wood backing. Has anyone used plastic or metal. Does anyone have backside Bezel photos of the process? Or after completion?
I was going to use ABS desolved in acetone for the glue/filler if that makes a difference.
Old Oct 17, 2007 | 04:43 PM
bbentley40's Avatar
bbentley40
Are you doing a monitor for a carPC or a DD head unit? My dash was for my carPC so I was able to get a headrest shroud that is made for the monitor and mold it into my dash. Now I can remove the monitor if I need to.. plus I didnt have to void the warranty on the monitor by opening it up so I could mold the front piece into the bezel.
As far as ABS vs Epoxy vs whatever else.. I used epoxy for mine and it turned out fine and didnt seem to be as messy as the ABS method looked.
Old Oct 17, 2007 | 04:59 PM
scott_fx's Avatar
scott_fx
i will try to take a picture this weekend. i used (my second time around) all abs. i used a combonation of abs sludge as well as a soldering iron to melt the pieces together. Def go with the abs sheets over the wood. much better results
Old Oct 17, 2007 | 07:41 PM
hangpilot's Avatar
hangpilot
Thanks for the answers. Where did you get abs sheets?
Old Oct 17, 2007 | 07:48 PM
scott_fx's Avatar
scott_fx
www.mcmaster.com i got the 1/8 sheet and it's working perfectly
Old Oct 17, 2007 | 07:55 PM
hangpilot's Avatar
hangpilot
Cool Thanks!
Old Oct 20, 2007 | 03:38 AM
Black$heep's Avatar
Black$heep
I used the plastic surround that came with my Avic D3, taped it in place , and molded around it. I think you might find the ABS desolved in acetone to be a real pain.
This is what I used.(Both from Wal-mart) The fiberglass resin drys fast and is sandable, same for the bondo professional gold. Bondo professional gold works best for plastics.
Here is my right up on mine. If you have any questions......I'll do what I can to help.
http://forums.corvetteforum.com/show....php?t=1819384
Old Oct 20, 2007 | 12:58 PM
scott_fx's Avatar
scott_fx
you'll be much better off with either the abs stuff, plastic bumper repair or plastic epoxy to bond the plastics together. (i've moded 3 vette dashes and one rx-7 dash. the rx7 dash was bonded with fiberglass and bondo and showed stress cracks eventually)
Old Oct 20, 2007 | 04:26 PM
Davinss's Avatar
Davinss
Hey does anyone have a their original ash tray/lighter door left over from doing the bezel mod? Mine is all scratched up...
Old Oct 22, 2007 | 02:05 AM
Black$heep's Avatar
Black$heep
I might. I'll check in the garage when I get home.
Old Oct 22, 2007 | 02:29 AM
scott_fx's Avatar
scott_fx
i took a couple pics of my backside...well...the dash's backside though it's 11:30 and i'm still at work, i'll try to upload them tomorrow. i took two pictures. one has the abs method and the other has the plastic weld
Old Oct 22, 2007 | 02:49 PM
hangpilot's Avatar
hangpilot
Waiting for your, ........uh, the bezels backside pics with baited breath. Well, ok, just bad breath.
To C5 Bezel modders - show us your backside
