Sponsored by: Innova
FAQ Question
Old Oct 19, 2007 | 02:31 PM
1Harley 1Vette's Avatar
1Harley 1Vette
Default FAQ Question
OK, Just to prove I read the C4 FAQ I have tried to answer a question and ended up with more questions. When looking at the wiring chart "General Motors 1979-Current" It shows 2 Yellow Wire's under the OEM column. One for "Ignition/Accessory" and 1 for "Rear Left - " . Which is it?
I have spent days ADVANCED SEARCHING the archives and assumed I needed an OEM Aftermarket Stereo converter in order to keep my existing Bose Amp and speakers on my 96 C.E. VERT. When I called CarToys to purchase one, they said I don't need one on the 96 Vert .
Is this ? Someone please tell me if I need an OEM converter and part # if possible.
Thank You All for your Time and Patience
Old Oct 19, 2007 | 03:01 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
if your car has bose and you are trying to replace the stock radio with aftermarket and keep the rest of your bose then yes you need an adapter, without research i couldnt tell you which one
sorry if im of no help
Old Oct 19, 2007 | 03:06 PM
1Harley 1Vette
Any information is helpful. Thanks for at least letting me know I need an OEM converter!
Old Oct 19, 2007 | 03:31 PM
pentavolvo's Avatar
pentavolvo
Honestly for 100 bucks more then the converter costs you could replace all 4 speakers and it would sound 10000x better then the bose ever did
Old Oct 19, 2007 | 03:45 PM
1Harley 1Vette
You may be onto something. According to the FAQ I think I can pull the cable cluster off of the Reciever but I would still have to pull new Speaker wires Correct? Can I use the cable between the reciever and new Head Unit or would that have to be repulled also?
Old Oct 19, 2007 | 07:35 PM
90 Convertible's Avatar
90 Convertible
Yes, metra makes a wire harness to connect an aftermarket reciever to the bose harness so you can get 12V, switched 12V, ground, antenna, etc. Then you would just need to run new speaker wires. You will also need a GM antenna adapter.
Old Oct 19, 2007 | 08:40 PM
VenkmanP's Avatar
VenkmanP
The speaker/amps are the crappy part of the Bose. Changing HU and keeping Bose speaker/amps is a bad idea.
Old Oct 19, 2007 | 09:11 PM
bogus's Avatar
bogus
Harley - do me a favour, stop all the cross posting... keep this stuff in one thread, and it will be easier to keep track of.
I have answered your big thread... this is redundant.
thanks.
To FAQ Question
