Got my C6 speaker replacement gear...
Anyways, I got replacement speakers for the doors and the rear. I'm just going to disconnect the center dash speaker. Also got Pipe's speaker mounts and a JL 300/4 amp to power the speakers. Going to have to move things around a bit in my rack, but shouldn't be too big of a deal.
Fronts: Focal 165V1 Polyglass 6.5 Components
$201.99 shipped
Rears: Focal 130CA1 5.25
$109.98 shipped
Amp: JL Audio 300/4
$338.78 shipped
Speaker Mounts: Pipedreams'
$50 shipped
Ok, got everything put in today. WOW! The difference is night and day and then some! I can really turn it up LOUD and it sounds clear without any muddy distortion. At normal volume everything is more clear and spatial without that flat mid-level sound throughout. Cost a bit more than they quoted for the install, but it took them a bit longer. They put a Power Distribution Block in for the two amps, which took a bit extra. Not too big a deal though, but in the end it sounds great. It really makes having the JL Stealthbox sound much nicer in the overall mix.
Front Door Speakers w/Dynamat Extreme around the plates, also some behind the speakers:
JL 250/1 amp powering Stealthbox along with the Power Distributor Block and the iPod hookup:
JL 300/4 amp powering the front/rear speakers:
Amp/Hardware Rack:
http://www.sonicelectronix.com
They said there we a licensed retailer...and one of the lowest prices I could find. There were a few other online stores with lower prices, but it was because they weren't licensed and Sonic wouldn't match their prices because of that.
http://mobile.jlaudio.com/jlaudio_pages.php?page_id=111
***ADDED PICS AND THOUGHTS IN FIRST POST***
I haven't had any issues with heat, but I don't blast it too loud for too long. But even when I have it's not really an issue. If things start to warm up, I can just lift the top off a bit and let it air out. No big deal.
I used to deny warranty claims all the time when I worked at a jl shop
btw, where did you get that amp rack? I was gonna build one similar to that
But I love how it blends and looks stealth...doesn't scream "hey i have an expensive system in here!"
looks good, what tweeter? I used to work at one
