Sponsored by: Innova
C5 Radio reception problem
Old Nov 6, 2007 | 09:26 PM
The Punisher's Avatar
The Punisher
Default C5 Radio reception problem
I installed an aftermarket stereo and a universal antena adapter.Now my radio reception is bad. The stock unit worked great. Any ideas ? .I have an '00 coupe
Old Nov 7, 2007 | 12:26 AM
SilverC54me's Avatar
SilverC54me
There is an antenna amp in the C5 Coupe by the drivers side seatbelt retractor. Check out my post in this thread.
http://forums.corvetteforum.com/show....php?t=1850259
Also search the C5 FAQ for additional info.
Old Nov 11, 2007 | 08:33 AM
The Punisher
I read your post.So exactly what did you do.Did you disconnect the pin wire or hook 12v to it? thanks
Old Nov 12, 2007 | 12:10 AM
SilverC54me
There is a drk green wire in the harness behind the radio, this is the signal wire for the antenna amp. Applying 12V to this enables the amp. The wire is on connector C1 Pin 8. Connectors C1 and C2 are joined together.
Pin 6 on C1 is the 5V signal that switches to the front antenna.
I would recommend only to apply the 12V to Pin 8 of C1.
Here is the connector info.
Old Nov 12, 2007 | 07:02 PM
markcz's Avatar
markcz
More info for you here.
Old Nov 12, 2007 | 10:03 PM
The Punisher
i will try putting 12v to the dark green wire
Old Nov 12, 2007 | 11:25 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
you need to read that thread and apply the 5 volts to that other wire as well for the best reception
Old Nov 12, 2007 | 11:26 PM
SilverC54me
That is the thread that I could not find.
Gary
Old Nov 12, 2007 | 11:31 PM
SilverC54me
I am running with only 12V applied to the Green wire. In my area (Orange County CA) that gives me the best reception. I tried it with the 5V applied and had better but drifting FM and still no AM. With just the 12V applied FM does not drift. If you apply 5V to the Pink wire AM reception will non existent.
Gary
To C5 Radio reception problem
