Sponsored by: Innova
where is the amplifier?
Old Nov 7, 2007 | 02:21 AM
ICANTDR55's Avatar
ICANTDR55
Default where is the amplifier?
I have a 92 vette and I was trying to replace the main amplifier does anyone know where it is. And im not talking about the amps in the speaker box.
Old Nov 7, 2007 | 04:09 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
I THINK what you are looking for is in one of the rear compartments, the ones that open uip in the hatch. My factory BLOSE is long gone. I have the abs stuff inside the one and a six disc changer in the other so I am not positive. This is JUST a GUESS if this were actual factual knowledge it would have been followed up with specifics.
Old Nov 7, 2007 | 06:50 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
there is no main amp. The only amps are the ones with the speakers. The system has the control unit in the dash and a receiver behind the seats and amps with the speakers. You might also click over to the audio/electronics section for more detailed info on the BLOSE system
Old Nov 7, 2007 | 11:45 AM
IrishJoker's Avatar
IrishJoker
Old Nov 7, 2007 | 02:22 PM
ICANTDR55's Avatar
ICANTDR55
the problem is that my radio won't come on and all it does is shows 1:00
any idea what that is?
Old Nov 8, 2007 | 02:00 PM
IrishJoker's Avatar
IrishJoker
Haven't had an issue with mine so I have not done any research - I am assuming you checked all the fuses? Does the Antenna go up?
To where is the amplifier?
