Sponsored by: Innova
Could somebody please tell me.....
Old Nov 19, 2001 | 02:46 PM
Wheelman's Avatar
Wheelman
Default Could somebody please tell me.....
what size speakers will fit in place of my bose speakers (front and back) without any custom fabrication.
I have an 89 coupe with bose.
Also, what is entailed in ripping out the bose system?
thanks
Old Nov 19, 2001 | 09:28 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Could somebody please tell me..... (C4Fetish)
4x6 front door and dash, 6x9 rear. You can also put with minimal effort 6 1/2 rear and front door. Dash can house a seperate tweeter easily as well. Since 4x6 speakers stink, this is what I would do. It does mean cutting the door panel. If you don't want to cut, get a 4 1/2 seperate combo and it can fit without cutting.
Ripping out stock =
Taking out deck(dash piece and a few screws)
Door speakers, dash speakers, rear speakers.
You will need to run speaker wire to all locations and install new deck with kit. About a 3 on a 1-10. If you are handy and have minimal know how you should get through it with our help and save a few bucks.
92TripleBlack
[Modified by 92TripleBlack, 8:30 PM 11/19/2001]
Old Nov 19, 2001 | 09:33 PM
Kale's Avatar
Kale
Default Re: Could somebody please tell me..... (92TripleBlack)
i still cant get the inner door frame off to put 6.5's in and remve the bose.
Old Nov 19, 2001 | 10:01 PM
92TripleBlack
Default Re: Could somebody please tell me..... (Smash)
Hey Smash
Did you remove the door panel and you are having problems with whats behind it? I haven't been in there for a long time but from looking at the replacement parts they look like they would just unbolt once the panel is off.
92TripleBlack
[Modified by 92TripleBlack, 9:06 PM 11/19/2001]
Old Nov 19, 2001 | 10:18 PM
-=Jeff=-'s Avatar
-=Jeff=-
you mean like this?
Old Nov 19, 2001 | 10:40 PM
Kale's Avatar
Kale
Default Re: Could somebody please tell me..... (-=Jeff=-)
exactly. Do yu9 just undo the visible parts? does that affect the window assembly? I wanna pt some cheap 6.5's in tonight.
Old Nov 19, 2001 | 10:53 PM
92TripleBlack
I would unbolt the black bose amp housing. It looks like it is about 3 times as wide as the speaker and just as high. Pretty big. Then, look at the hole you have. Run the window up and down and see where the parts go. You will need to mount them in the hole and make sure they avoid the window parts. Finally, I would mount a board inside the door (behind the metal) in the bose location. With the window in mind, cut a hole in this board and mount the speaker in the hole. Use MDF. It should fit behind the stock grille location. If you can't get it to fit because of the depth, you will probably have to mount it on the outside of the door panel. What speakers do you have? Did you get those kickin focals?
92TripleBlack
Old Nov 19, 2001 | 11:08 PM
Kale's Avatar
Kale
I'm gonna pick up a $100 set of Infinity Reference coaxial just to make itsound better for the next few months. I'm selling the car.
I'll get the Focals in my new car. I'm thinking Oldsmobile Aurora.
Old Nov 20, 2001 | 04:54 PM
-=Jeff=-'s Avatar
-=Jeff=-
Not sure if your 86 has the same window mechanism as my 89.. if os they are all 7mm screws and one 10mm.. I think as long as you line up he 10mm one again you will be fine.
I don't think it will affect the windows.. but I could not tell you. right now I cannot roll mine down due to the interior swap
Jeff
Old Nov 20, 2001 | 05:23 PM
Kale's Avatar
Kale
Got it out. the rods were a pain in the butt. there a better way to deal with thm?
Old Nov 20, 2001 | 09:29 PM
-=Jeff=-'s Avatar
-=Jeff=-
not that I found.. they seemed to be decent for me to work with
Old Nov 20, 2001 | 09:50 PM
Kale's Avatar
Kale
did you dynomat the wood plate that you attached to the door? I foam taped the back of the speaker..
To Could somebody please tell me.....
