Sponsored by: Innova
C3 Subwoofer install question
Old Nov 25, 2007 | 02:46 PM
srosa75's Avatar
srosa75
Default C3 Subwoofer install question
I need some advice from you audio gurus. I installed a subwoofer in the storage compartment of my 76. The inside of the compartment is lined with dynamat type stuff.
The subwoofer is "recommended" to be in a sealed enclosure. I was thinking about building a box type structure within the storage compartment, and putting in some acoustic foam. Is this a good idea or is it worth the effort? I am getting pretty fair bass, but I think I should be getting more. The storage area is anything but a sealed enclosure at this point.
Old Nov 25, 2007 | 07:59 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
You definitely need to get it in a sealed enclosure. To operate properly there needs to be back-pressure. So build a box you can fit in there and also make sure you built it to the interior volume recommended for the driver as well.
Old Nov 26, 2007 | 09:51 AM
DPG's Avatar
DPG
St. Jude Donor '06
seal that bad boy up.
To C3 Subwoofer install question
