What DIN size is Eclipse nav?
1) the JVC KD NX5000, but I've read that it's actually larger than 1 DIN, but not as large as 1-1/2 DIN, so a standard HUMOUNT kit doesn't quite fit, and
2) the Eclipse nav unit with the flip-up screen, but I don't want a flip-up screen that blocks the air conditioning vent.
There are 4 or 5 other Eclipse nav units that are true in-dash (i.e. not flip-up) - are all of these 2 DIN?
Any guidance from those with Eclipse nav units would be greatly appreciated.
And btw, if you are gonna take the dash apart to install the head unit, you can easily move the heat/ac to the top spot and mount the flip out in the second spot (may have to cut a bracket, but very easey).
Poof, no blocked ac vent
