Educate me on the C5 Audio system
- Does the car have internal amplifiers???
- Can I just replace the speakers and use the existing wiring thst runs to the headunit? This will allow me not to have to rewire the doors mainly.
- I want to add a power antenna. I know there is a how to. Is there a parts list. the how tostates to use a switch. I plan on contolling it at the headunit.
- Will I need any special harnesses other then the HU harness? I am thinking interfaces or bypasses.
I don't plan to do anything wild this time. Maybe a nice 6.5 componant up front. 5.25 componants in the rear with a sub in the center dip and a 5 ch. to run it all off a new hu.
The front 8" speakers are amplified by a small onboard amplifier on each speaker plate
I wouldn't. It's about the easiest car in the world to run wire in. Get some wire at walmart.
Well you connect it to the blue lead on the HU, but I'm not sure of the other bits.
No, just the small generic GM head unit harness. Available at walmart for like, $6. You will need to tap accessory power elsewhere.
You can run rears with the head unit's power, if you really want rears. That way you can focus money and power up front.
Kale has answered most of your questions, as for the amp thing you need to ask yourself how loud you want it to be. I can put you in line for a nice 5 channel amp that will fit underneath the z06 passenger seat that will push your whole system. If you really wanted to keep the rears (I suggest against it) you could run them off of the HU power if you wanted. I personally recommend a HU with a built in crossover and EQ, but the amp I have in mind has some decent flexibility in the crossover department.
To be honest, unless you are pushing 1000w per side over 50' runs, you really don't need 14g wire. I do most everything with 16g myself /shrug
Shoot me a PM or give me a ring and you can swing by one night after you get off work and check out my install for ideas.
Fej
A couple quick answers to the questions will sufice
