Sponsored by: Innova
Adding Subs to Stock C4 Bose???
Old Nov 23, 2001 | 10:23 PM
92corvette's Avatar
92corvette
Default Adding Subs to Stock C4 Bose???
I searched but couldn't find any posts form people that have added just subs and amp to their stock Bose Gold. I have seen it done in a 96 but the owner didn't know how it was interfaced. I looked around the internet and found and Audiolink product that claims to work for this purpose. Has anyone used the Audiolink product or any other method.
Before you suggest it, I did consider and almost went aftermarket, but I found a replacement head unit and speakers for very cheap so I'm sticking with it for now. :)
Thanks...
Old Nov 23, 2001 | 11:56 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Adding Subs to Stock C4 Bose??? (92corvette)
Nope. The only way is to get a speaker wire to feed a high power input on an amp or a powered sub. Bazooka makes such things but they sound lousy like the stock system. Or you could add an adapter like the audiolink. Also add several hundred to your system and engine noise with either option. You really can only add quality bass if you go aftermarket. In this case figure $600 minimum without the sub. A good system with sub, $1500.
92TripleBlack
