Front speaker challange
The best answer is to remove the forward segment of each door panel and customize the back side for midranges while adding tweeters in the dash. Like this :
So how in the world did you get 7" mids stuffed in there? Looks like a 4" is all that would fit from what I can see. Got any other install pix?
Mark
I decided to mount the tweeters in the upper door panels which brightend the sound stage and now the music sounds great.
The problem with the 90-96 door panels, are that both sides are not symetrical. You can modify the passenger door panel easy enough but, the driver side door panel is a lot tighter.
Here's a couple pictures.
Infinity Kappa's installed.
Tweeter relocated to the passenger door panel.
Tweeter relocated to the driver side door panel.
The driver side was considerably easier than the passenger side which required a sort of 'funnel' to get the response right. The main drawback was poor right-channel midrange response for the passenger (but quite good for the driver). I went through 7-8 variations of positions using the doors, dash and factory rail locations. The rails were awful in every instance, even when using very good drivers. While the tweeters were merely OK in the upper door panel, the whole soundstage opened up when I found just the right spots in the dash.
I went through both ideas GKK has, but quickly found them both to be unacceptable. I know my version requires a lot of work, but after several years of measurements and trial/error, I found it's the best alternative.
GKK, that is a good idea on the floor because the new mounting board will allow speakers with more depth than the stock mounting plate. You can also angle the speakers a little better. I may try some 5x7s on the floor and tweeters up on the dash like Spkrboy.
Thanks for the ideas everyone.
how are the 7" aimed? are they off axis or one axis? if on axis how are they mounted.
I know that there is room to mount the speakers in the doors. I also don't like the door sill mount. Although I had a 4 and tweet mounted to the sill, they sounded decent, but were easily blocked by the legs of the driver and passenger. that same system had a 6.5" in the door..
Maybe the 2 way will work better with the 6.5 in the door with a tweeter mounted like GKK did
FWIW, I'm extraordinarily picky about sound quality. Audio is important enough to me to go to these lengths, and it was not a simple task. The C4 is far-and-away the hardest vehicle into which I've ever tried to get a high-quality system. In the end, it was (to my ears) merely tolerable. After several years and countless attempts, this was the only solution I could live with.
Spkrboy, As you stated there is not really any room on the drivers side to get speakers on axis. I was all set in doing the tweeters and mids in the sill, but now I need to rethink things.
I like the set up bogus has with the 6.5 in the sill, the 4" in the door and the tweeter above.
I have a thought of that but need to see how/if I can fit the 6.5 in the sill, if so that might be a better route..
Athought the mid in the drivers door gets somewhat buried in the dash with the door closed
Jeff... I was never a fan of Orion drivers. Loved their amps, but speakers were a different story so they may have been the problem. As far as using the sill for a midbass, well, I haven't come across a midbass yet that was small enough to fit down there yet good enough to justify trying to integrate. The closest I came (still not really all that close) were the Kicker RMB6s. After messing with those, my hatred for Kicker grew exponentially. That's why I used very large mids. In the driver's door, if you take care, there is enough room to slightly tilt the driver. Nothing tremendous, but it's better than nothing.
I really can't emphasize strongly enough how BAD the factory locations are. Maybe Bogus will add to this?
I could ditch the 4" and use the 6 and Tweeter with the EF X-over or run active on a 2way in the front. I would like to use the drivers I have and might try to pitch the driver door speaker on axis.
As for the Sills, I could build out a bit, as I HAD to on my 89, since it had the 91 dash I had even LESS depth but I had something working. I have extra sill grilles to use and build out a bit for a 6.5" with might work out and the put the 4 in the door with the tweeter in the door/ Dash and see how that works.. I dont think the legs will be that big an issue with the mid bass..
where is bogus with his input??
Speaker recommendation is a tough thing. For car audio stuff I like Focal Polyglass components. Given my choice, I prefer raw drivers from Seas, Focal and Vifa with my own custom-built crossovers.
Also for Crossovers if you have the Amplifier channel capacity you could do active crossovers instead of the passives
