It's not hard if you want to try the basics. All you need is a hand-held calculator and some basic knowledge of when and when not to vent a box. And you don't need to be a bass-head to try a vented box. For some drivers, it's better.
you could build a box with variable port length that could be changed depending on your mood.
Well, since choosing a tuning frequency isn't a choice (it's calculated based on the driver and the box alignment) and unless you can find a way to vary the box size at the same time, it won't work. Again, sorry.
