I've got the center councel out for an intsall in my 07 C6. Has anyone found a switched power I could use for juicing my goodies? While I'm at it I could use the threads for install of the door 3.5's and rear 5.5's.
The C6 Audio FAQ stickied at the top of the section(and linked in my signature below) has threads that address alot of this.
There is no switched power in the factory stereo harness because it gets it's on & off commands from the digital serial bus. I have used the wiper fuse in the passenger footwell as a switched source for a 12V trigger.
If you're installing an aftermarket head then you need a module like the Peripheral GMCO or GMAH24(B) anyway, and that will have a switched 12V output.
