Sponsored by: Innova
Help with PAC OEM-1
Old Dec 23, 2007 | 07:31 PM
Archdog75's Avatar
Archdog75
Default Help with PAC OEM-1
I am installing a Pioneer Avic D3 and I want to keep my bose speakers in my 2002 Corvette Convertible. I have the Pac Oem-1 for the corvette.
I know I have to connect the Avic d3 pigtail to the pigtail of the Pac, right?
The PAC adapter has two parts, (one on each side of it) Both ends have white plastic connectors,
1- 11 pin
1- 4 pin
1. These both plug in the two factory connectors that use to plug in the factory radio?
Then with the 11 pin connector, branches off with a 18 wire pigtail
2. Does this pigtail connect to my pioneer's pig tail?
Pioneers pigtail has the following:
purple - right rear positive
purple w/ black - right rear negative
green - right rear negative
green w/ black - left rear positive
gray - right front positive
gray w/ black - right front negative
white - left front positive
white w/ black - left front negative
ILL - Connect to the Illumnation wire (Cream Colored on the HVAC Plug)
ACC - Where?
+battery - Where?
Antenna Control - Where?
Reverse Gear Signal Input - Connect to reverse lights, but where??
Car Speed Signal Input - Connect to either PCM on passenger side or under the Gauge Cluster. Which is easier and faster?
Braking Brake - Connect to parking brake wire under console
Black Ground - Connect to chassis ground
pac adapter
white w/ blk - Matches (-) Left Front
gray w/ blk - Matches (-) Right Front
green w/ blk - Matches (-) Left Rear
purple w/ blk - Matches (-) Right Rear
black - Ground
blue - Matches Power Antenna
orange - Illumination/Dimmer ***Not Used
blue w/ white - AMP Trigger ***Not Used
red - Ignition/Switched (can I connect to this? Instead of tapping into the brown wire under the ignition...)
yellow - Battery
purple - (+) Right rear high level
purple w/ red - (+) Right rear low level ***Not Used***
green - (+) Left rear high level
green w/ red - (+) Left rear low level ***Not Used***
gray - (+) Right front High level
gray w/ red - (+) Right front low level ***Not Used***
white - (+) Left front high level
white w/ red - (+) Left front low level ***Not Used***
3. What wires used? and What wires not used? On the PAC Adapter. Am I right?
4. And the longer lose red wire connects to switched igintion power?
I did look in the FAQ and didn't see anything about the PAC...
If anyother tips for my install that would be great.
Thanks in advance,
Justin
Old Dec 24, 2007 | 07:12 PM
InSaNeKaMeL's Avatar
InSaNeKaMeL
am in the same boat.. but i dont know any of it... hope someone helps.
Old Dec 30, 2007 | 06:40 PM
DefenderC5's Avatar
DefenderC5
There is a few of us in this boat... I just opened up all my boxes and feel I may be in over my head on this one.
I also have the AVIC-D3, OEM-1 Adapter for the bose speakers, and no clue.
Old Feb 9, 2008 | 04:32 AM
InSaNeKaMeL
anyone figure it out?
Old Feb 9, 2008 | 01:16 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
yeah the answer is the pacaoem1 isnt the right adater, the oem1 is for an aftermarket amp with stock deck
to keep stock amp/speakers you need the soundgate adapter
Old Feb 10, 2008 | 10:57 PM
Archdog75's Avatar
Archdog75
Yes, the Pac adapter works with an aftermarket deck with stock speakers.
The Following wires used and not used:
pac adapter
black - Ground
blue - Matches Power Antenna and it does work with my vert antenna
orange - Illumination/Dimmer ***Not Used *** Use the wire-A.C. Control
blue w/ white - AMP Trigger ***Not Used becuase its when adding amp to stock system,,, Not needed
red - Ignition/Switched - Connect to a remote turn on, Use a fuse that turns on when ACC on
yellow - Battery
Its simple when you actually look at the wires coming from the adapter. Look at the pigtail.... not all wires continue to the actual pac adapter. Like look at the white w/ red wire - it ends at the pig tail and does not continue.
Its easy, just use good connections for all the wires and then zip tie them up.
Old Feb 10, 2008 | 11:09 PM
pentavolvo's Avatar
pentavolvo
do you have the roem or aoem adapter
Old Feb 11, 2008 | 01:25 AM
InSaNeKaMeL
thanks for some of the clearing up i may have to give it a second shot
Old Mar 4, 2008 | 03:35 AM
InSaNeKaMeL
i got it all hooked up and it works but i dont have any bass... dont know what to do, just thinkin of addin a sub again
Old Mar 4, 2008 | 10:04 AM
pentavolvo's Avatar
pentavolvo
your bose amps arent turning on did you hook the remote/amp turn on wire from the d3 to the remote/amp turn on wire on the pac adapter
Old Mar 4, 2008 | 11:49 AM
InSaNeKaMeL
no i think i missed that. i will check it out later. thanks any chance u recall the wire colors?
Old Mar 4, 2008 | 01:42 PM
pentavolvo's Avatar
pentavolvo
check your owners manual for the radio it might have 2 of them a power antenna and an amp turn on. you want to use the amp turn on if there are both choices they are blue or blue with white stripe
take this amp turn on wire and run it to the blue wire off the pac adapater should be called amp turn on or power antenna etc
Old Mar 4, 2008 | 01:52 PM
InSaNeKaMeL
thanks man i will try it out later tonight.
Old Mar 4, 2008 | 05:34 PM
InSaNeKaMeL
got it working right now thanks man
Old Mar 5, 2008 | 06:41 AM
VET IT B's Avatar
VET IT B
I am in the process with a Z2. I have the ROEM-VET 1
Is this the right one? Mark
Old Mar 5, 2008 | 09:12 AM
pentavolvo's Avatar
pentavolvo
yup
Old Mar 16, 2008 | 08:55 AM
VET IT B's Avatar
VET IT B
Finally got everything wired up in my Z2 last night and fired her up. Couldn't believe it, everything is up and running and seams to be wired ok.
I would like to thank everyone for their help and patience with me. Brian (C5-KIDD) was very helpful with my questions on the PAC hookup and great to deal with on the purchase of everything.
I have to get everything back in and I have several pics that will be comming. Thanks again, great form for all of us. Mark
To Help with PAC OEM-1
