Sponsored by: Innova
Opinion needed from speaker guru(s)--
Old Dec 26, 2007 | 10:17 PM
VinceC5's Avatar
VinceC5
Default Opinion needed from speaker guru(s)--
I've always used cone type mids, but what I'm planning now requires a shallow mount midrange...
Anyone have any experience with the Dayton RS52AN-8 2" Dome Midrange:
http://www.partsexpress.com/pe/showd...number=285-020
Old Dec 26, 2007 | 10:52 PM
Kale's Avatar
Kale
I've heard that it's extremely articulate, but also very very bright.
Old Dec 27, 2007 | 06:50 AM
Spkrboy's Avatar
Spkrboy
It's a very good driver. Lower limit is about 600 Hz, upper is about 4500, both assuming 24 dB/oct acoustic slopes. A 12 dB slope will move both numbers. Beyond those points, distortion increases dramatically. You'll likely need some impedance compensation at the crossover point to the tweeter. If you intend to use 3-way active, things will change somewhat, but a few passive components will still be necessary to get it to sound its best. Just in case it's overlooked, this thing is over 5" in diameter.
To Opinion needed from speaker guru(s)--
