Circuit board or electronics gurus needed within
Lemmee see if I can find something....
I'd guess 9744 is date code, 1997, 44th week, so I will see if the other is a base P/N number.
In my younger days the symbol would have made me know the mfgr, but it does not ring a bell...
EDIT:
Okay, it's National Semi...
http://www.chipdocs.com/manufacturers/NSC.html
I hope this helps?
Not sure if it's a reference number or what (probably just a coincidence)---but it appears to be your component.
everything is highly integrated these days...
anyway, Intersil P/N RFD16N02L is what I could find:
* pin-out should work
* voltage should work
* amperage should work
* case type should work
You can plug the P/N into Google to find a lot of places to buy (in qnty) if you know someone in the industry, sometimes they can often sample them in small quantity for free if they have an account, but usually there is a sales call follow up to see if they want to place a larger order...
I can't guarantee the part will work, but my confidence is 85%.
Info and datasheet here:
http://www.datasheetcatalog.com/data...16N02LSM.shtml
I hope this helps?
EDITE TO ADD -- Actually it's a TO-220!
He he he
Well, both your's and mine are ~ 30 V D-S, enhancement mode N channel power MOS FETs, general purpose switch or driver....but yours has a better chance of being the item... although, I do have to say that line number is more likely happenstance than the number stamped on the part...
So I'd get a:
BUK455-100A/B
Confidence here is 95%.
Normally the controller is not a serviceable component. It is simply replaced.
If you successfully replace the MOSFET on the board, let us know.
There may be other components on the board that have thermal stress.
Good luck with the repair.
Thanks guys for all your help. It was my fault it failed, I was doing some "testing" when one of my headlights was making a weird noise ( I now know it is a stripped gear and am getting the bronze one) when some wires I was using to test touched
Stupid me
So now one headlight will go up and down and the other because this is fried will not. I thought it would be simple to find this part take out the old one and solder in the new one. Finding this thing is the most challenging part so far.
There are some used ones on ebay but looking over the board this seems to be the only issue. Seemed like a easy repair or at least worth a shot since the part is going to be cheep if I ever find it I have repaired boards before and usually can tell when more is fried. I can tell you the board smells like crap!
EDIT:
Its been too long for me...you are wise beyond words! I haven't got into the guts of electronics in a long time and it shows.
You are getting some good advice from those advising you may just want to get a replacement unit.
For instance, the older FETs lacked gate protection, so it is easy to zap them with static (ESD) while you handle it, unless you take care.
It's clear a lot of current has gone through area of Q2 (compare to Q1), and so it is indeed possible that there is another component that is bad as well... I've seen boards that carbonized so badly that they themselves became a conductor, and I had to scrape them of the carbon to try to salvage... at some point, ya gotta be willing to throw in the towel
at the end of the day, if I could lay my hands on the transistor, or even one near like it, I'd take a shot (not likely to do more harm than is already done!), but I would not spend too many hours on it -- sometimes you just have to suck it up and buy the module...
I love to tinker, but I always make sure I remember whether I am doing it for the fun, or thinking I am saving a buck -- often times, 'saving a buck' goes out the window pretty quickly!
Good luck, and tell us how you make out.
What I have learned is to be more "cost effective" in what I delve into, but I also like finding out what went wrong.
Power mosfet and probably a N-channel.
You can cut the "g" (gate) lead and measure if the D & S are shorted.
If they aren't and you can power up the board, activate the failed mode and see if you get any drive voltage measured at the gate (goes high or low).
If so, jumper the D & S leads and see if the failed mode works.
