Sponsored by: Innova
Got information on how to install CD Changer
Old Nov 30, 2001 | 11:05 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Got information on how to install CD Changer
as most of you know by now, I was having a MAJOR problem installing the factory CD Changer in my '98 vert.
the 4 wire plug for the changer harness was there but the 3 wire plug was nowhere to be found!
as it turns out, this is not a problem unique to my car.
I'm not sure if it is only the '97- '98 C5's that might be wired this way, but if you cannot find the 3 wire connector for the CD Changer then you will need to use this information.
another forum member (california quicksilver) has posted the procedure to the other thread I started in C5 tech.
I posted a "Tech Tip" on the subject for anyone else that might be having a problem.
:cheers:
