Anyone have wiring diagram for 2000 vette
Whoever had the car before me did all kinds of stuff to the wiring of the stereo. I plugged in this new head unit to the stock harness and the unit doesnt stay on. It powers on if you hit the "display" button or the eject button, but turns off about 3 seconds later. Anyway, all the wires back there are butchered and I need to make sure its not that instead of pointing fingers at the head unit. Ive searched and found posts for this, but all with broken links. Please help me out with this. I just need the stereo wiring diagram. Thanks.
Here is an excerpt from a post that appears to be long gone
The Bose CD/Cassette head unit can be utilized without the Bose signal conditioner. Bose subwoofer amps and speakers by using the head unit four pre-amp outputs to drive external aftermarket power amplifiers and speaker. Use the Shielded wires or chassis for signal return. DO NOT USE signals Common on C4(13), LT BLU or Common C4(7) YEL. These are the only interface to the Bose signal processor.
The head unit RADIO ON output can be used to switch on external power amplifiers. Be safe and use an inline .5 amp fuse to protect the head unit.
Wiring Info
The following are the Bose head unit 4 channel pre-amp outputs
Signal CD/Radio Color Code
LF out C4(9) TAN/BLK
RF out C4(10) LT GRN/BLK
LR out C4(11) BRN
RR out C4(12) DK BLU
Common C4(13) LT BLU – DO NOT USE FOR EXTERNAL POWER AMP
Shield C4(14) Bare Wire
Ground C4(15) BLK
The following are the Bose head unit 4 channel power amp inputs
LF C3(1) DRK GRN
RF C3(2) LT GRN
LR C3(3) BRN/WHT
RR C3(4) BLK
Common C3(7) YEL – DO NOT USE FOR EXTERNAL POWER AMP
Shield C3(8) Bare Wire
The following are the Bose head unit power and control signals
Signal CD/Radio connection
SW+12 out C1(18) DK GRN – Radio “ON” Signal
Power C1(10) ORG
Ground C1(5) BLK/WHT
