Sponsored by: Innova
Removing AVIC from C6 - Need Help
Old Feb 1, 2008 | 03:02 PM
zich6's Avatar
zich6
Banned Scam/Spammer
St. Jude Donor '08-'09
Default Removing AVIC from C6 - Need Help
I'm removing a professionaly installed AVICZ2 from an '08 C6Z. Can anyone give me step-by-step directions such as:
1. Remove fake carbon fiber trim
2. ????
3. ????
Thanks.
Old Feb 1, 2008 | 03:15 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
go to c6 faq, look up and of the dbl din install guides, specificially the dnx7100 one it shows how to get dash apart pull avic out and the harness/bose adapater hope no wires were cut up by installer and plug stock unit in
Old Feb 1, 2008 | 03:16 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
2. ????
3. ????
Thanks.
In my signature just below there's a link to the thread I wrote up for the install of my system. Included in there are instructions for removing the console. I haven't done an '08 so I'm not sure how that leather-looking trim attaches, I assume it's attached to the console trim piece. Since I know people have put the '08 console trim in prior model years my guess is the procedure is the same.
You have a bunch of screws to remove and a terrifying pull of the console trim that you will hate, but it's what has to be done.
After that it's just removing the screws holding the radio in and disconnecting wires.
Old Feb 4, 2008 | 05:36 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
the 08 is similar, but you will need to twist the ring below the shifter (i don't think 05-07's you had to twist) to get the boot to come down to expose the bolt holding the shifter **** on. Other than that, it is the same thing as previous years.
To Removing AVIC from C6 - Need Help
