Sponsored by: Innova
i have a c5 in
Old Feb 1, 2008 | 10:51 PM
Beardown3's Avatar
Beardown3
Default i have a c5 in
which I have replaced the head unit with an AVIC-N1. All speakers/wiring have been changed and I have am amp for the speakers and one for a seperate large woofer. The sound of CD's and XM radio is fantastic. However, I have taken the car to a number of places and the FM reception sucks bad. I even had the head unit and the brain switched out and to no avail, the same issue with reception. The power antenna wire was hooked up properly I believe but I dont knw what to do to get decent reception. They keep telling me its because its a vette and there is no good grounding points, however I dont hear anyone else having this issue. Any suggestions or recommendations would be greatly appreciated. THX beardown3
Old Feb 2, 2008 | 01:51 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ill assume you have a coupe, there is a special 5volt lead that needs to be enabled
http://forums.corvetteforum.com/show....php?t=1338065
also check out C5 faq it should be in there
