Sponsored by: Innova
i POD for a MB?
Old Feb 7, 2008 | 02:55 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Default i POD for a MB?
Wife has a SLK350 , 2005 , with the Nav system, I was looking to hook up a Ipod to it, call the dealer and they say bend over, want $350. for the kit, $250.00 install. I have seen the wireless genric hook ups but thinking the sound would not be good? Can some one help me here?
Old Feb 7, 2008 | 03:27 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
wireless transmitters are junk, and $250!!! for install
i just did one of them for one of my customers (actually sirius, but I still had to remove the radio)
It took me all of 10 minutes to get the radio out.
this is from memory, so just take your time.
remove the trim around the shifter ****
remove the wood grain piece around the shifter (the bottom piece)
take out the ash tray, and remove the screws (i believe they are T-15 or T-20)
pull out the HVAC controls
there should then be 2 more screws near the hazard switch, remobe them
open cup holder, and take out the 2 screws
that should clear the dash leaving you with only the radio, and 4 screws.
connect to the back of the radio, and run the cable into the glove box, or where the wife wants it.
put back in reverse
good luck
Old Feb 7, 2008 | 05:24 PM
mojo1's Avatar
mojo1
Thanks, is there another solution besides droping $350 on the kit from the dealer?
Old Feb 7, 2008 | 05:38 PM
scott_fx's Avatar
scott_fx
check out sound gate, peripheral, and pac-audio for there ipod interfaces. they may have one for your car
Old Feb 7, 2008 | 06:40 PM
mojo1's Avatar
mojo1
no luck !
Old Feb 7, 2008 | 07:56 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
If you have to resort to FM then at least go with something that's wired-in via the antenna wires, not wireless. While not as good as AUX it's far better than wireless FM.
Old Feb 7, 2008 | 08:59 PM
mojo1's Avatar
mojo1
details? on the menu there is AUX ,could I hook it up through that some how?
Old Feb 7, 2008 | 10:59 PM
scott_fx's Avatar
scott_fx
i think he's referring to an fm modulator
Old Feb 8, 2008 | 08:19 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Yes, I am. Here's an example:
http://www.crutchfield.com/App/Produ...MMOD01&tp=1701
It plugs into 12V power and inline on the antenna to the radio (for a MB you'll like need Euro antenna adapters in & out, easily had). You set it to a frequency in your area like 88.7 or something, then tune your radio to that frequency. By being plugged inline on the antenna wire you are eliminating most of the radio frequencies battles you fight with the wireless versions.
I don't know anything about the MB cars, but if they are like my former '04 Saab using the MOST system then it may very well be your only option. Those radios are a nightmare to deal with.
Old Feb 8, 2008 | 08:34 AM
mojo1's Avatar
mojo1
Thanks for the information , I appreciate it !
Old Feb 8, 2008 | 09:36 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Hardwired RF modulator was only option in my gfs car for her ipod, hoesntly 99% of ppl wouldnt know its a hardwired rf modulator they would think its built in to radio
Old Feb 8, 2008 | 10:53 AM
Jimmy 2 Times
hardwired FM mods are much better than FM transmitters, but not as good as AUX.
Also, if you get a Modulator, remember to pick up 2 Euro antenna adapters (about 10 bux each)
Old Feb 8, 2008 | 11:02 AM
mojo1's Avatar
mojo1
Will do ,
What , do I do to hook up through the AUX.??? sorry for so many questions. Hell I may just break down and get the $350 kit and do the install myself, I found a write up on it, at least then it would be integrated through the Nav system screen , right?
Old Feb 8, 2008 | 11:28 AM
Jimmy 2 Times
if it is an OEM MB piece, then yes, it will work thourgh the factory navi
install is not hard at all. I would bet 30 minutes start to finsih with a beer break
Old Feb 8, 2008 | 01:36 PM
mojo1's Avatar
mojo1
Thanks again , if it s that short then 2 breaks will be in order .....
Old Feb 8, 2008 | 02:03 PM
53389's Avatar
53389
yes u can, i do it all the time. have the dealership ACTIVATE the aux programing, the aux jack to plug in your mp3 player should be in the glove box. Look carefully, use a flashlight, it will either be on the sides or top of the glove box from the inside, it looks like a black button with a hole in the middle of it. It will take a mini plug.
First see if you can find aux jack and try it out, sometimes this feature is already activated by the dealership.
Completely read your cars owners manual audio section, it might be described there also.
Old Feb 11, 2008 | 07:29 AM
mojo1's Avatar
mojo1
Thanks for info, I did not see a plug in the glove box, just my luck!
To i POD for a MB?
