Sponsored by: Innova
Replacing Bose system
Old Feb 14, 2008 | 09:35 AM
roanoke2's Avatar
roanoke2
Navigator
Default Replacing Bose system
I'm replacing the bose system in my 89 vette with a non-bose system, and wonder why I can't use the existing speaker wires. I disconnected the wire from the door amp, and ohm check it from the head unit connector, I got a complete reading. So why should I not use this wire? Don't want to screw anything up. Thanks for any help you can give.
Old Feb 14, 2008 | 10:56 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
no reason you couldnt if they all ohm out. i seem to remeber those cars sharing a common ground for the low level signal meaning this wouldnt work
imo just put some aftermarket speakers in and an aftermarket radio instead of the non bose but to each his own
Old Feb 14, 2008 | 06:03 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I think Penta is right, that they have a common ground. I know most people run new wires. Let us know how you make out.
Randy
Old Feb 15, 2008 | 07:17 AM
roanoke2's Avatar
roanoke2
Navigator
Thanks, I'll be working on it next week, and plan to do some more research before I go forward with the install. Will let you know what I find.
Old Feb 18, 2008 | 02:26 PM
VetteStir's Avatar
VetteStir
I did this just this over past weekend and you CAN use the old wiring on aftermarket speakers. Just remember to cap off the 12v and ground wire that power the amps! The problem I'm having now is, I bought 6.5" speakers and can't figure out how to mount them in the existing front location? I went with a pioneer head unit, component speakers in the front with 6x9's in the rear. Possibly a sub in the future. If any one has any ideas on how to reuse the door locations for aftermarket 6.5" speakers, feel free to chime in.
Old Feb 18, 2008 | 06:20 PM
gbarrett's Avatar
gbarrett
Last weekend I put 6.5 coax speakers in the doors. I made an adapter from some acrylic sheets using a Dremmel tool to cut the circle. Works fine except for the speaker cover, but I'll make those next weekend.
Old Feb 21, 2008 | 08:20 AM
VetteStir's Avatar
VetteStir
I was thinking of ordering some new door carpet (without the speaker cutouts) and just hiding the door speakers that way. Should be a nice clean look, but I'm not sure of the sound I'll get?
Old Apr 26, 2008 | 09:05 AM
gdc's Avatar
gdc
Carpeting over you front speakers will kill your high frequency in both volume and sound quality. I'd try to have some opening.
Old Apr 28, 2008 | 08:04 AM
VetteStir's Avatar
VetteStir
I have tweeters exposed in the upper portion of the door (component system) with 6.5" woofers down below (covered by carpet). Sounds Great!
To Replacing Bose system
