Sponsored by: Innova
Install Question...?
Old Feb 19, 2008 | 09:06 PM
kris6868's Avatar
kris6868
Default Install Question...?
how much sqaure ft dynamat you think to cover c5 vert. trunk floors and doors? also anyone got a good write up to take out all interior carpet? thx kris
Old Feb 19, 2008 | 09:35 PM
slplank's Avatar
slplank
Can't help with the Dynamat but I believe the carpet removes easily in 3 pieces. I've read best to start in the rear and work forward. The rear piece breaks right behind the rail behind the seats. I've had that out and it is simple.
Old Feb 19, 2008 | 10:02 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
80 sq ft did the same area on my hatchback coupe. It should be the same on your vert. The cockpit carpet can be taken out once you remove the seats, the center console and the arm rest compartment.
To Install Question...?
