Sponsored by: Innova
VSS Wire Location on a C5?
Old Feb 22, 2008 | 12:05 PM
Vegas Vette's Avatar
Vegas Vette
Default VSS Wire Location on a C5?
Can someone tell which wire is the VSS and its location on a C5?
Thanks for any help.
Old Feb 22, 2008 | 10:37 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The speed sensor is located on the rear differential.
Old Feb 22, 2008 | 11:50 PM
Archdog75's Avatar
Archdog75
About the Speed Control wire, I tapped into the green/white stripe wire in the stock wire harness for the original stock sterreo. The stock sterreo uses the speed to adjusts the volume as you increase your speed. I believe someone posted a pic of that wire. I tapped into it for my avic d3 and I have no error messages and I checked the wire connection in the menu of the avic d3 and it said "Connected" and it displays my speed.
Its easy to install, I thought it was going to be hard, but its not really.
Speed Sensor wire:
Hope it helps,
Justin
Old Feb 23, 2008 | 12:20 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Speed Sensor wire:
Hope it helps,
Justin
That's an easy solution. I thought you might have to tap into out by the battery area where all of the PCM and tranny harness connectors are.
Old Feb 23, 2008 | 04:24 PM
Vegas Vette
Thanks for info guys that was very helpfull.
Old Feb 27, 2008 | 05:34 PM
JUSTAKAR's Avatar
JUSTAKAR
Default Well done Justin
Justin,
Exactly what we were lookin for...great stuff..and thanks.
Ian
Old Feb 27, 2008 | 08:43 PM
minitech's Avatar
minitech
I did this and it seemed to work but I had no pulses. Went to the green with white #7 in the gauge bezel and it works fine
Old Nov 4, 2008 | 11:00 PM
macro76's Avatar
macro76
where is the #7 in the gauge bezel? believe me, i dont wanna open this up again
Old Nov 5, 2008 | 10:07 PM
minitech's Avatar
minitech
Between #6 and #8. Just count from the end. The big tip is it is a green wire with a white stripe. There are two wires coming out of it with that same color. One is for oil pressure I think.
I have read someone getting it by just removing the knee bolster and reaching up for the Green wire with White stripe (Not removing the bezel.) Seems you might risk connecting the oil pressure to the VSS for a few seconds while you look for speed pulses on your unit; you would have it set up with the right screen to look at before doing that. But it probably wouldn't hurt anything. If it doesn't work change to the other one.
I ended up pulling my cluster to place aluminum bezels and did it all then.
Incidentally, many times when someone asks for the VSS someone invariably posts a pic of the transmission and says that connector is where the VSS is. That IS where it ORIGINATES but it has absolutely nothing to do with people trying to find it for a NAV setup. Not helpful information. I wonder if those people do it to be sarcastic.
Old Nov 6, 2008 | 01:18 AM
heavymetals's Avatar
heavymetals
You don't have to remove the gage cluster but a mirror and a good light will make it easier for ya to locate the connector release and unplug it from the cluster.
Right behind the left hand side of the gage cluster.
Old Nov 9, 2008 | 10:41 AM
macro76's Avatar
macro76
does anyone hav a pic of the green with white at the gauge cluster?
Old Nov 10, 2008 | 03:08 PM
RKGarner's Avatar
RKGarner
I am in the middle of installing a Avic-Z2 in my '01 Z06. Now I confussed. So the green wire w/white stripe behind the cluster and the green wire w/white stripe in the radio connector and the green wire w/white stripe at the PCM are not the same? Eeie Meenie Miney Moe?
Old Nov 10, 2008 | 03:59 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
cluster or pcm is the place to go, IMO cluster is easiest
Old Nov 10, 2008 | 04:29 PM
RKGarner's Avatar
RKGarner
Thanks, I was ready to connect to the green wire w/white stripe in the radio connector. I guess I'll cut my loses and go to the cluster. I agree with macro76
Old Nov 16, 2008 | 09:05 AM
BitViper's Avatar
BitViper
I swear....whenever I read pin bla at connector BlaBla.....I go nuts...
Pictures..pictures pictures..
Thanks all
To VSS Wire Location on a C5?
