Sponsored by: Innova
avic d3
Old Feb 23, 2008 | 07:24 PM
animesk8er93's Avatar
animesk8er93
Default avic d3
ok i had the d3 installed about a month ago
and it use to turn off with my car
but the last week i put in the ipod wire
and it still turned off with my car for about a week
but now it doesnt turn off automatically
and i turn the screen off manually but i dont want it to run my battery down and i want it to be automatic does anyone know why this is happening
Old Feb 23, 2008 | 07:42 PM
markcz's Avatar
markcz
What year car, and do you know which interface they used? Did it work with RAP or just turn off with the ignition?
On my D3 it powers on/off with the car and RAP (turns off when I open a door, not turning off the ignition). The iPod will remain powered on for 10 minutes or so AFTER the car and D3 power down, that's normal, and it will eventually turn itself off. I think that's the D3's way of making sure the iPod is charged for the next use, who knows.
Is the iPod what you're talking about or is the D3 itself staying on?
Not to run you off, but if it is a problem with the D3 you might get better help at this site:
http://www.avic411.com/forum/
Old Feb 23, 2008 | 08:57 PM
animesk8er93
it turned off when i turned the car off and opened the door
and no the d3 screen stays on
how do i completely turn it off manually
the shop that put it in didnt give me my manual
and
that shop sucks im not taking my car back that and sadly i live in the middle of no where and dont have time to drive to a different shop
i have a 2007 a6
Old Feb 23, 2008 | 10:15 PM
markcz's Avatar
markcz
To turn it off manually go to the AV Menu screen and hit the OFF button in the bottom right corner.
It sounds to me like the interface they used to connect the D3 to your car went bad. It's supposed to monitor the data line and control the accessory power to the radio, like it used to, not keep it on all of the time. It could be worse, it could have failed in OFF.
You can get a pdf of the manual by clicking here
Old Feb 23, 2008 | 10:21 PM
markcz's Avatar
markcz
I suppose it is possible that the red power wire (switched) is touching the yellow (constant) power wire. You did say that this started after you hooked up the iPod cable, so you may have pulled something a bit too tight.
Try taking the dash apart again and checking that the red and yellow wires going from your interface to the D3 aren't touching. If they aren't, unplug the wires from the back of the D3 and see if the red wire has +12VDC coming out of it even when the car is off. If it does, your interface is kaput, but should still be under warranty if it's only been a month.
To avic d3
