C6 - You don't need a Cleansweep
So this thread serves to answer that question and will become the link in the FAQ with that big, obnoxious statement I made.The Cleansweep is designed to be used to integrate factory systems in cars where you simply cannot get line-level, flat analog audio output. By line-level I mean RCA jack signal, not amplified speaker output. By flat I mean that there is no signal processing applied, no EQ curve, no loudness, no crossover, etc. A number of the European car companies utilitize the MOST optical system where you just can't get analog output, or even in those where you can there's a viscious EQ curve built-into the signal. The Cleansweep is designed to take the output of those kinds of systems (at the head or at the speakers, whichever) and "clean" it so that the output is flat and you can then connect it's output to an aftermarket amplifier to upgrade the system.
The C6 head units (both Bose & non-Bose) output line-level, flat signal which can be tapped in a variety of ways. I wrote this how-to a while back for those who don't mind tapping into the wires directly. If you'd rather not do that, you can get a PAC ADD-GM24 harness from Sonic Electronix, hack off the output connector and solder on some female RCA's and use it as a "T" connector and that will also work and be a bit cleaner & easier install and un-install.
OK, so we've established what the Cleansweep does and the nature of the output of the C6 head units. When you compare those two things it becomes obvious that the Cleansweep is not needed in the C6 because the type of signal the Cleansweep provides is already available as-is.
So, save your $300 and if you're using an installer print this thread to show them that they're flat-out WRONG about your car if they advised the use of a Cleansweep.
You don't need a Cleansweep in the C6!!
We originally tested the output of the C6 head unit using a PAC AOEM-GM24 and saw a very unpleasant loudness curve. Based on that information (and ill-placed faith in PAC) I purchased a Cleansweep. But my ears were telling me something was still going on, something missing and so we tested the PAC module itself and found that the loudness curve is in the OEM-1 box that makes up the base of the AOEM-GM24 module and not the head unit. So then we tapped the wires directly using only the harness portion of that module without the OEM-1 box in the mix and the results were flat. There are threads, I believe linked in the FAQ as well, that show the steps along the way, along with the results.
How can I explain it to them. Maybe I should go elsewhere?
Can anyone simplify?
They seem like a reputable company with plenty of install experience and have said they've done vettes before...
Obvioulsy I have these two options if I proceed then..
1) Keep factory HU, add a new amp, new speakers & ipod adaptor,
NO cleansweep.
Oh I found out the their explaination for cleansweep. The Bose system outputs a non-flat signal from HU and it must be converted to flat signal before signal reaches new external amp. Also, mentioned the cleansweep will allow for an aux input for ipod therefore the ipod2car apaptor is not necessary. (Therefore, price of Cleansweep now cut in half?)
2) Remove OEM HU- Get latest HU w/features and Don't worry about non-flat signals
Let me add all your advice/experience has been very educational.
thanks again
and i tapped into the driver side rear speaker by just splicing the rca wire into that.
when the volume is low you can here the sub barely, and when you turn it up the sub cuts off completely.
the amp is still on but no sound at all from the sub.
Is the amp/ sub pulling too much of a signal? or not getting enough signal?
Best way to get RCA line level signal is by making one of these
Also, the full frequency signal isn't present at the rear speakers, so your sub won't be playing as much bass as it should.
