Sponsored by: Innova
What Speaker For: C6 w/ D3
Old Mar 1, 2008 | 11:44 PM
NEV3R L8's Avatar
NEV3R L8
Default What Speaker For: C6 w/ D3
I had an epiphany today while driving...The stock speakers SUCK. I will be installing the AVIC-D3 in the future and am getting ready to order all the parts I will need. So I can add/change my list what parts will I need to install the AVIC-D3 including the D3? Also what speakers do you recommend? I've heard that most people just removed the rear speakers because it adds too much noise, is this true. I've looked around and searched but its always better to get personalized help.
-David
This is what I figured:
-D3
-Metra Dash Kit
-Sirius Tuner
-iPod Cable
-Speakers?
-Subs?
-Amp?
Basically I want the D3 w/ iPod and sirius connected to whichever aftermarket speakers you guys recommend but I don't know which is the best way to approach that...
Old Mar 2, 2008 | 01:45 AM
805Z06's Avatar
805Z06
-David
-D3
-Metra Dash Kit
-Sirius Tuner
-iPod Cable
-Speakers?
-Subs?
-Amp?
Your headed in the right way. But to get some useful feedback, you should give us more details of your goals.
For example:
1) Subwoofer. Are you looking for a clean and simple install. Would a sub box like a JL Stealth be something you want? Or are you looking to put bigger subs and want a larger box in the hatch? Basically, the stealth look or an obvious system look.
2) Speakers will vary. How much are you willing to spend? You can get some good quality speakers for $200-$500. The best way is to go out and compare for yourself. I heard JL Audio, I liked them and the price, so I am going to go that route. There is also Focal, Alpine, ect..
3) Amp. There are so many choices. But if you are trying to go for the stealth look, consider Alpine, they got some small sizes.
Things to add to your list.
1) Steering control module. Do you want to use your radio buttons on your steering wheel.
2) Harness module. This will be needed to connect to your HU to the factory harness.
3) Amp wiring kit.
Old Mar 2, 2008 | 10:24 AM
NEV3R L8's Avatar
NEV3R L8
For example:
3) Amp wiring kit.
1. I think that the JL stealth box would work perfectly. I don't need that much bass. but would I be able to put one on both sides or just one?
2. I don't really know which speakers I like the best right now. I think pretty much anything would be better than bose I just want something that won't cost too much.
3. Amp - I want to go either as stealth as possible or as easy as an install as possible. Would I have to make some kind of amp rack? Has anyone ever put it behind the passenger seat?
Also I don't have steering controls and which module would I need to hook up to the aftermarket speakers?
Old Mar 2, 2008 | 01:35 PM
805Z06's Avatar
805Z06
1) JL Stealth Box, is a very clean looking box. Some people feel that it is to expensive. I was going to get one but I was sold on Boxology (sponsored vendor) version. It looks very similar. You can put a a larger 10 JL sub and you don't have to bolt it down to the car. This makes it easy to take out of the car if you have to.
I will be getting mine next week.
2) For the front speakers, I would go to to 6.5 inch component route. WWW.nakidparts.com sells the speaker adaptor for your door. Find a local stereo shop and try to get an idea of which ones you like. I would then order them online for the best price.
3) I got the Alpine and it's size is quite small. I am going to be installing it in the car within the next week or two. My plan is to put it behind the passenger seat (floor or the wall). My goal is not to have an Amp rack, I want it stealth as possible.
When you have a chance, check out my thread I posted. It goes over a lot of things that you are looking. I got a lot of good feedback from the members here.
http://forums.corvetteforum.com/show....php?t=1949736
For the factory harness adaptor, you need to do a search, there are a few options to choose from. Do you have Onstar & Bose ( I assume so since you said earlier).
Old Mar 2, 2008 | 06:55 PM
NEV3R L8's Avatar
NEV3R L8
I'm interested in how you mount the amp. Your setup sounds exactly like what I'd like to do.
I do have Bose but no Onstar so it really shouldn't make a difference right because I won't be keeping anything Bose anyways.
Old Mar 3, 2008 | 12:52 AM
805Z06's Avatar
805Z06
I will do a write-up when I get the system in. I think it might take another week or two. I still have to finish the insulation on my car.
In regards to the harness, I believe that you will need this;
PAC ADD-GM24 Harness to add an amp
http://sonicelectronix.com/item_5944_PAC+ADD-GM24.html
PAC AMP-RCA
http://sonicelectronix.com/item_5942_PAC+AMP-RCA.html
Old Mar 3, 2008 | 12:49 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
those arent the proper harness u listed, thats for adding an amp to the stock headunit, not replacing the headunit. Check c6 faq the harness are listed in there. i believe its a gmos-04 u need to replace factory headunit
Old Mar 3, 2008 | 02:36 PM
NEV3R L8's Avatar
NEV3R L8
Even if I will be Changing the whole system. Head Unit, Speakers, Amp, Subs?
Old Mar 3, 2008 | 03:45 PM
805Z06's Avatar
805Z06
My bad, all this speaker and amp talk made forget about the HU going in.
That gmos-04 seems like a PITA...make sure you read all the threads on it beforehand..
Old Mar 3, 2008 | 03:47 PM
805Z06's Avatar
805Z06
Yes, even if you change the whole system. The audio system is not a stand alone. It connect with your chimes, and a lot of other stuff I don't know about .
The good thing is that harness will plug into your factory harness and there might be slight modifications required. You should find the instructions with the harness or the guys will help.
Old Mar 3, 2008 | 04:03 PM
pentavolvo's Avatar
pentavolvo
Since you are replacing everything but i assume you still want chimes, get the nonbose interface harness and run a line from that to the center speaker which will act as your chime. Now if for some reason you didnt want chimes at all techincally you could get away without a fancy harness. PM me if you are unsure etc
Old Mar 3, 2008 | 05:57 PM
805Z06's Avatar
805Z06
I would disconnect the center speaker. It sounds better without it.
Old Mar 3, 2008 | 06:46 PM
NEV3R L8's Avatar
NEV3R L8
K well I'll probably just wait to see how you handled it and probably go from there. But what if I wanted to keep my factory speakers but add a sub with either the JL box or that other company called Boxology or something. How would I do that considering I already have the D3 installed with I guess the GM0S04 for instance (not sure if thats the one I need or not)? I guess I would need an amp for just the sub. I've helped my brother install a system before and have a pretty good feeling for what needs to be done but I guess I just don't know what parts to get and how to go about doing it.
Old Mar 3, 2008 | 09:09 PM
805Z06's Avatar
805Z06
Try to keep it simple.
GMOS-04 will work. That harness will allow you to connect your factory wires with the D3. Even if you keep your stock speakers or not.
If you are going to do it, do it right.
D3
Good quality front speakers w/ mounts
JL sub w/ Boxology
Amp (small but enough to power speaker and sub)
Harness (GMOS-04 or anything similar)
Check out http://www.sonicelectronix.com/
There prices are very good on most items. You should be able to get these items cheaper than you think. Plus you will save some money from Boxology.
Old Mar 3, 2008 | 10:59 PM
NEV3R L8's Avatar
NEV3R L8
This forum is evil lol it drives you to want bigger and better things lol. I think you've helped point me in the right direction as far as equipment. I'll put a list together of what I think I need and just have C5KIDD go over it before I order to make sure I have everything. Then I'll check back in with you guys to let ya know how everything is going. Thanks for the guidance.
To What Speaker For: C6 w/ D3
