Sponsored by: Innova
C6 2005 Vert lockpick Installation
Old Mar 6, 2008 | 12:55 PM
systems's Avatar
systems
Default C6 2005 Vert lockpick Installation
Where did you route the IPOD cable to? and not have it exposed when coming from the Waterfall?
Do you use the AUX feature at all for the lockPick? I was thinking it could support my Zune... but don't know if it would work.
Thanks for any thoughts/pictures...
Dave
Old Mar 6, 2008 | 01:07 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
run it under carpet and into center counsel
that aux will work for ur zune etc
Old Mar 6, 2008 | 01:33 PM
systems's Avatar
systems
thx!
Old Mar 6, 2008 | 01:51 PM
pentavolvo's Avatar
pentavolvo
to get it under carpet and into center counsle is very easy
prly gotta undo the bolts on the back of counsle so u can lift it up a bit
Old Mar 7, 2008 | 09:59 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Yes, there are about 4 nuts fitted over studs mounted into the console that need to be removed. Under that is an insulating pad. Best pic I have:
Old Mar 7, 2008 | 11:35 PM
systems's Avatar
systems
Thanks for the pic's, My order is in...
To C6 2005 Vert lockpick Installation
