Cooling Fans causing electrical noise
I’m currently running the fan power switch from the amp’s turn-on-lead to a 5v power regulator to the Stinger SFC temp switch. (seen here) The fans run at half power when the amps are on and 100% above 90 degrees.
http://cgi.ebay.com/STINGER-AUTOMATI...QQcmdZViewItem
Ground is separate from the amplifiers.
How can I get rid of the noise?
