Tweeter mounting location, C5
has anyone put their tweeters in this location?
my second choice might be something like the above owner did:
but I don't want the tweeters to be that visible to onlookers and I would like them closer to me if possible. if niether of those ideas work for me I may go for the door pull thing which is also discussed in the Audio FAQ.
so some questions for those who have installed components and tweeters before:
my first question above, can a tweeter be mounted on the inside surface of the A-Pillar? it looks pretty flat, but I don't know if the strucural member there would be in the way.
how do you remove the A-Piller? looks like its just metal clips, but I don't want to just pull on things hoping they will pop off without breaking something.
since the pillar is vinyl wrapped, how does one make a hole in it? do I have to worry about ripping the vinyl and making tears which are visible after the tweeter is installed? is it glued to the pillar over the entire surface? since I've never tried cutting into it before, what should I do? how do I do it right?
if I go for the door pull installation, are there any step by steps on this? I've seen a pic of the final product, but havent run across any detailed pictures of how it was done, how the door pull was removed etc.
thanks in advance!
I recently attempted tweeter mounts similar to Kale's over the weekend. However they will be re-done. This was my first experience in fiberglass and I made a couple of mistakes:
a) on the drivers side A-pillar, I attempted to fiberglass ONLY the area around the molded section. this created a horrible crease where the fabric stopped that not even a well sanded section of bondo could totally remove.
b) on the passenger side A-pillar, i made the mistake of using a foam brush to apply the fiberglas resin. I didn't use enough and as a result the sanding didn't turn out well.
The good news is that I was planning on throwing away these A-pillars anyway. I damaged the mounting tabs the first time I re-installed them so they're going to have to be replaced. The Imaging is significantly improved from the original "drill and mount" versions.
Once i get new A-pillars, I will be remaking the moldings using the proper technique and materials.
In these locations, you can still use an A-pillar gauge pod. In addition, the time correction between woofer and tweeter is minimal on the drivers side and identical on the passenger side.
problem is reflections are a bitch. imagine an invisible, wide, cone that extends out from your tweeters. If that cone touches anything, it will mess up your sound. If it touches glass, it will _really_ mess it up.
Flush mounting would be tough, there really isn't a flat surface on the pillars, and there isn't a spot that's deep and wide enough for a tweeter.
downside is that the tweeters face almost directly left or right, so the passenger's tweeter will face the driver, but the driver's will really not face anywhere (into the contours of the gauge cluster)
or I could use the angle mount pieces that come with them and mount to the outside of the pillar and angle the tweeters more towards the passengers. I just don't want it to look too ostentatious.
Step 2: stick tweeter in, use silicone sealer on the back to hold in place.
step 3: enjoy poor imaging, top end response, and extreme side bias.
I tried this first in my set up. I was actually able to get it sounding OK with some clever work with a parametric EQ. Forget about imaging though. Still was better than bose.
well, in the C6 i did, this location worked out fine
of course it varies with tuning and the tweeter involvedb
