C6 non bose aftermarket radio ?
Ok quick question regarding non bose c6 cars. Ive put units in multiple bose cars and the only non bose car I did was when the C6 first came out so I cant remember how it went. I searched and find info here and there but figured a few of you guys know the C6 better then me.
Going to use the GMCO harness
Does the stock amp have a 12volt or 5volt turnon. In my searching I see some ppl mention it as 5volt turn on meaning I need to reduce voltage.
Also if I recall ground loop isolators on the RCA are a must and will eliminate any poping noises on turn on and off
TIA
TIA
