Sponsored by: Innova
Configured the best??
Old Apr 7, 2008 | 04:20 PM
C6_blackhawk's Avatar
C6_blackhawk
Default Configured the best??
Here is my new setup. Keep in mind that I did all the work myself... so that might explain a lot.
My setup includes 2X 10" Kicker Comp low profile subs (400 RMS, peak 800, 4 ohms) being powered by a 1400 2-channel Amp. I also have a 2 farad capacitor connected to the amp. I have the PAC OEM-1 (GM24) adapter with the RCA outputs. I have the stock Nav w/ BOSE. I've connected the "rear" RCA outputs to the amp. What I'm wondering is what is the best way to setup the system, other than what I have it as. I have 1 channel going to one sub and the other channel going to the other sub. It sounds "alright", I wasn't sure if there was any tricks to setting it up to sound its best. How should I set the levels on the BOSE? Should I leave them all in the middle and then mess with the bass levels on the amp? Also, should I turn up the mids and treble now that I'm adding more bass?
Below is a picture of the enclosure I made out of MDF and fiberglass.
Thanks in advance!!!
Old Apr 7, 2008 | 04:29 PM
TorchedC5's Avatar
TorchedC5
My setup includes 2X 10" Kicker Comp low profile subs (400 RMS, peak 800) being powered by a 1400 2-channel Amp. I also have a 2 farad capacitor connected to the amp. I have the PAC OEM-1 (GM24) adapter with the RCA outputs. I have the stock Nav w/ BOSE. I've connected the "rear" RCA outputs to the amp. What I'm wondering is what is the best way to setup the system, other than what I have it as. I have 1 channel going to one sub and the other channel going to the other sub. It sounds "alright", I wasn't sure if there was any tricks to setting it up to sound its best. How should I set the levels on the BOSE? Should I leave them all in the middle and then mess with the bass levels on the amp? Also, should I turn up the mids and treble now that I'm adding more bass?
LOL tracked you down again.. get me the model of the subs and amp. That way I can tell you how to wire the subs in
Old Apr 7, 2008 | 04:30 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
if that amps a pyle replace it and it will sound like 10x better right away
Old Apr 7, 2008 | 04:32 PM
TorchedC5's Avatar
TorchedC5
LOL don't hate.. eh, i doubt that amp is 4 ohm stable...
Old Apr 7, 2008 | 04:33 PM
C6_blackhawk
REALLY?? I had a pyle in my last setup....I thought it was decent... that bad huh??? I thought an amp did one thing.... put out watts... But if you say so, I'll get another one.
Old Apr 7, 2008 | 04:34 PM
C6_blackhawk
Ohh no... jokes again?? I think it jumps between 1 and 8... so 4 is like right in the middle.. whats wrong with that???
Old Apr 7, 2008 | 04:37 PM
TorchedC5's Avatar
TorchedC5
Well atleast give us model numbers so we can figure out how to make it sound alittle better...
Old Apr 7, 2008 | 04:42 PM
C6_blackhawk
AMP: 1400 WATT PYLE PLA2200
Subs: KICKER Comp VT CVT10 SHALLOW 10" (400RMS, 800MAX)
CAP: TKO 2.5 FARAD DIGITAL 20V CAPACITOR
Old Apr 7, 2008 | 04:50 PM
TorchedC5's Avatar
TorchedC5
GRR wont tell me what the power is bridged at 2 or 4 ohms.. this is frustrating.. lol
Old Apr 7, 2008 | 04:52 PM
TorchedC5's Avatar
TorchedC5
Nevermind I had a stupid moment.. go positive to positive and negative to negative on the subs, then bridge the amp..
Old Apr 7, 2008 | 06:03 PM
C6_blackhawk
Well, I just want to thank TorchedC5. He helped me UNF@CK my setup. It sounds MUCH better now!! Still keeping in mind that the "powerhouse" Pyle amp is the bottleneck of the setup. Hopefully no one else will buy one of these crappy amps. Thanks again!! Sounds LOTS better!!
Pentavolvo... you were right... I didn't realize the Pyle was such a crappy amp. I have now seen the light.
Old Apr 7, 2008 | 07:10 PM
TorchedC5's Avatar
TorchedC5
No problem, this is why I love this forum. Blackhawk is a top notch guy and it's hopefully the start of yet another good CF friendship!
To Configured the best??
