I want to install my new Alpine, but all the local shops tell me that I need a $199 Bose interface to be able to hook it up to the Bose amp and speakers. I looked at PAC, but can't find the right one to install on my '03 Z. So, Question One: Do I need the interface and, Question Two: If so, which one do I need? Thanks for any and all information.
Basicly with the adapter, you match the wires from your deck's harness to the adapter and then just plug in the adapter into the stock harness.
You can do it by yourself for much cheaper. Everybody here on the forum can help you through every step. Check out the C5 FAQ that is stickied at the top. It has alot of info that is really good.
oh, yes you do need it. Without the adapter, you will lose the bose subs in the doors if you're keeping the bose speakers. If I was you, just replace the front speakers and be done with it. The bose speakers suck actually. I thought the bose speakers were ok, but I am in the process of replacing my bose speakers.
Thank you. I would change the door speakers, but that also needs an adapter. Don't want to spend the money to buy those when I can make them myself. Will buy the adapter for the Bose system for now. Your help is greatly appreciated.
basically get you need soundgate gmcrv2 for liek 100 bucks, or get regular gm harness, make some baffles from mdf and some coaxials for less money and be ahead
