Sponsored by: Innova
Door sound deadening
Old Apr 15, 2008 | 07:32 PM
bowtiebubba's Avatar
bowtiebubba
Default Door sound deadening
I am looking for some sound deadner for my doors. Does anyone have some they want to sell or recommend a reasonably priced brand to buy?
Old Apr 15, 2008 | 08:04 PM
Kale's Avatar
Kale
raamat is the best bang for the buck
avoid edead. cliffnotes : many square feet of cheap garbage do not equal a few square feet of good product
Old Apr 16, 2008 | 11:19 AM
CraigE's Avatar
CraigE
I used Raamat on the outer skin,flats & verts, inner skin (both sides) and covered it all in Ensolite . I double layered the areas suggested on the http://www.raamaudio.com/cgi-bin/index.cgi website. I talked to Rick several times and he was very helpful. I just completed the inside of the removable door panels with Raamat. Although it is a lot of work, I'm very happy with the results. The prices are very good.
Old Apr 16, 2008 | 11:25 AM
Fasthotrod's Avatar
Fasthotrod
Rick is a super guy, and also a Corvette Forum member.
Mark
Old Apr 16, 2008 | 06:48 PM
Team DCA's Avatar
Team DCA
I personally use Dynamat. Probably not the cheapest but I know it works. Keep an eye out for the real cheap versions as some of them seep a residue into your carpets after time.
I have also heard good things about Raammat as well.
Old Apr 19, 2008 | 12:07 AM
805Z06's Avatar
805Z06
My vote is Second Skin. Impressive results.
Old Apr 19, 2008 | 12:34 PM
bowtiebubba
How much do you usually put in the doors of a C5?
Old Apr 19, 2008 | 02:36 PM
805Z06's Avatar
805Z06
You can get a little crazy with this stuff. The door are very misleading. They can take more material and time than what you would expect. I got about 10 lbs on insulation in each door.
It's up to you. I would do a box of Damplifier Pro and a sheet of Luxury Liner for both doors.
Old Apr 19, 2008 | 04:41 PM
bfrazelle's Avatar
bfrazelle
Just picked up my Z from the local audio store. Had him replace Bose with Eclipse and JL Audio, and while he was in there, placed a lot of Dynamat under seats, rear hatch and doors. The quietness is unbelievable! This stuff really works in making the car a GT style car. According to the installer, was quite easy, but time consuming, FWIW.
To Door sound deadening
