Sponsored by: Innova
Best Amp dor SQ? Audison/Alpine
Old Apr 17, 2008 | 10:48 PM
Gideon's_Test's Avatar
Gideon's_Test
Default Best Amp dor SQ? Audison/Alpine
I've heard many good things about both amps...
I'm looking at:
Alpine PDX 4.100 (4x100w @ 4 Ohms)
Audison SRX4 (4x60w @ 4 Ohms)
As for a little background info
Active crossover setup:
HU: Pioneer Premier DEH-P880PRS
Door Tweets: Seas 27TFFNCG (80w RMS @ 4Ohms)
Door woofer: Mach 5 MLI-65 (100w RMS @ 4Ohms)
Any thoughts/comment/opinions?
Thanks,
-Jason
Old Apr 18, 2008 | 12:04 AM
Kale's Avatar
Kale
The PDX will run those speakers just fine. I'd go for the least expensive one that best fits your install.
Old Apr 18, 2008 | 07:33 AM
Spkrboy's Avatar
Spkrboy
The Alpines I've heard are a bit harsh, but then again, that was driving a set of Focals. Swapping in an Xtant in place of the Alping PDX made a large improvement, so it was certainly the amp to an extent. I'd go with the Audison unless that much power is important to you, IMHO.
Old Apr 18, 2008 | 07:56 AM
Gideon's_Test
Well...If it makes any difference, where i found them, there is only a $20 price difference between the two...
Old Apr 18, 2008 | 08:20 AM
YO-EL's Avatar
YO-EL
I use Zapco amps
Old Apr 18, 2008 | 09:38 AM
ssmith100's Avatar
ssmith100
That's not even close. Audison by a wide margin. I've been running JL slash series for years and have been very happy with them but after listening to the Audison and Zapco amplifiers I would make a change. I have a PDX in my truck and it will be getting sold soon. Very harsh.
Shane
Old Apr 18, 2008 | 09:51 AM
Gideon's_Test
So you'd give up a bit of power (volume) to gain the sound quality of the Audison...Hmmm...
Old Apr 18, 2008 | 09:54 AM
Gideon's_Test
Well, I can go with the Audison, and if the power is insufficient, I can bridge it and buy another two channel...
Old Apr 18, 2008 | 09:55 AM
ssmith100's Avatar
ssmith100
Depends on the efficiency of the drivers. My Morels can take a ton of power but I've had them playing on as little as 75 watts a channel and they had plenty of volume and sounded fantastic.
Shane
Old Apr 18, 2008 | 10:25 AM
Gideon's_Test
Here are the specs:
The MLI-65 woofer:
Power Handling - 100 watts RMS (Maximum)
Sensitivity - 89db (2.83 volts)
Impedance - 4 Ohm (SVC)
The Seas 27TFFNCG tweeter:
Power Handling - 80 watts RMS (Maximum)
Sensitivity - 91db
Impedance - 4 Ohm
Old Apr 18, 2008 | 10:28 AM
Kale's Avatar
Kale
Audisons are usually a little underrated. It should be fine.
Old Apr 20, 2008 | 05:23 PM
1FASTVERT's Avatar
1FASTVERT
St. Jude Donor '12
Damn, I just bought an Alpine PDX 5 to drive my Focals and JL Audio sub. I almost wish I would have seen this before I bought it.
Old Apr 20, 2008 | 05:31 PM
CraigE's Avatar
CraigE
I have Audison LRX Series w/ stock nav/HU and it sounds really good.
Old Apr 20, 2008 | 06:01 PM
Kale's Avatar
Kale
I dont think my PDXs sounded harsh at all. They did, however, sound different... Sort of like all of the speakers were closer together.
I prefer the sound of my new ARC KAR amps, but miss the alpine's efficiency.
Old Apr 20, 2008 | 06:06 PM
805Z06's Avatar
805Z06
My PDX sounds really good. It's small and very clean unit. The best part of it that it does not heat up, very efficient.
To Best Amp dor SQ? Audison/Alpine
