Sponsored by: Innova
1989 Vert w/ bose ....speakers question
Old Apr 19, 2008 | 07:03 PM
guno89's Avatar
guno89
Default 1989 Vert w/ bose ....speakers question
I had a new Pioneer deck installed today. Of what I understand the speakers shouldn't work, they do. It sounds like crap and I plan on replacing them tomorrow.
So from what I read in the FAQ the amps are built into the speakers.
Am I correct to assume I can just pull the speakers out, cut the speaker wire loose from the factory amp/speaker and just splice the wire into my new speakers??? or is there more to it?
Old Apr 19, 2008 | 11:49 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i believe the c4s had a common ground to the amps meaning you actually need to pull new speaker wire but i could be wrong
Old Apr 21, 2008 | 09:12 AM
guno89's Avatar
guno89
Well I pulled the rears out, what a pain. I removed the enclosure and used the existing brackets to make slots for 6x9's. ordered some 4way Fosgates,
next weekend I will remove the fronts. can some one recommend some speaker sizes. I have read 5 1\4 and 6 1\2 works. I want to get the speakers in advance. is there one brand that fits better than the other. I don' feel like to doing to much modifications. I would like to stay in the $80-$125 range.
I'm not into car audio and I really don't know to much. Just looking for a overall good sound. I have Infinity's in my daily driver and going to them from my Fosgates was a major dissapointment.
Old Apr 25, 2008 | 11:10 AM
yaknow's Avatar
yaknow
Old Apr 25, 2008 | 11:16 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
From everything I have seen and read, 6 1/2 is the biggest in the front,
You have to run new wiring, if taking out the stock speakers.
To 1989 Vert w/ bose ....speakers question
