Sponsored by: Innova
Wire termination ???
Old Apr 24, 2008 | 03:16 PM
CraigE's Avatar
CraigE
Default Wire termination ???
What is the best way to terminate wiring into a screw-in connection like on an amp, for both speaker and power cables ? It seems bare wire just gets destroyed if it is the kind that the screw comes into direct contact with the wire. I guess you could solder the wire tip, I also saw something called maincrimps. Just wondering what the REAL professionals do.
Also do you guys like the gold plated crimp fittings for speaker attachments and ring terminals ?
Old Apr 24, 2008 | 03:17 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
either go under the screw if u can do it decent or use these http://sonicelectronix.com/item_7251...al+-+RED-.html
Old Apr 24, 2008 | 04:07 PM
VinceC5's Avatar
VinceC5
add solder to the wire tip or solder on some spade terminals and then protect with heatshrink wrapping.
Old Apr 24, 2008 | 06:29 PM
Team DCA's Avatar
Team DCA
I would go with the previous suggestions on the spade terminals. It is a solid termination with no question of stray wires. Makes things more reliable when there are no stray wires making unwanted contact.
To Wire termination ???
