Where does the green "remote turn on" wire coming out of the PAC OEM1 hook up????
I know the blue wire out of the output side hooks up to the amp, but on the other side of the PAC there is a green wire in the same position and it doesn't go anywhere, just a 8 inch long piece of green wire????
Mine had no sticker, but I found it, it's the blue wire in the plug thats on the passenger side of the radio.
I kept trying to make it work with the blue wire on the drivers side plug. it would turn on the amp after the radio was on, but wouldn't turn it on with the radio...
All's better now, it's back together and sounding pretty killer!!!
