Sponsored by: Innova
The dreaded radio!
Old May 1, 2008 | 01:55 AM
Master__Shake_'s Avatar
Master__Shake_
Default The dreaded radio!
I figured since the radio doesn't affect performance, that this would be a better section to pose a question. I have an aftermarket JVC system installed in my car, with a 12-disc CD player underneath the back hatch. The radio has never worked, nor the cd or cassette player. When I turn on the sound, I can hear fuzz according to how loud it's set, and gets louder with treble. I'm stumped as to whether the amps are really blown or there's a missing connection for the cd-player.
Any ideas of where I should start?
Old May 1, 2008 | 05:54 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
The audio and electronics section.
Old May 1, 2008 | 09:28 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
more info needed what year car and did you install this or was it already installed
Old May 1, 2008 | 10:06 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
His is a 86, says so on his profile.But you need to give more info?
Are you using stock speakers/amp or aftermarket?
If aftermarket, did you use stock wiring?
How is the changer hooked up?
Old May 1, 2008 | 12:26 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Does the radio work? If it does, and your problem is just w/ the CD, it is the changer that is the problem, or the wires that connect it to the radio. First off, make sure the changer has power, could just be a bad fuse. Do a google search on the brand and model numbers to see if you can find the manuals, and use them to trouble shoot the problem.
Report back w/ what you find out.
Randy
Old May 1, 2008 | 12:57 PM
Master__Shake_
It was installed when I got the car, but I do believe the speakers are stock Bose. The radio does not work, and I can't even get it to function let alone get a station to come in. Not sure about an aftermarket amp or not, but I don't even know where they snaked all of the wiring. It goes under the paneling behind the seat. Guess I have to take a look for some online manuals.
The whole section around the cassette player/clock does not work at all. It rewinds a tape and that's about it. I checked all the fuses last night after I blew out one on my dashboard. Everything else checked out fine.
Old May 1, 2008 | 02:41 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Get a new speaker or a loaner from a friend and hook it up. Sounds like the HU is bad or it blew out all the speakers. Stock radios are only 1 ohm, so usually you have to replace the HU, wiring and speakers when you get an aftermartket, though some have found away to use the stock speakers and wiring with no problems.
To The dreaded radio!
